Trans temp gauge reading 8123, limp mode...!?
I have a scan gauge 2. Today on the way to work my truck went into limp mode, the tow haul light was flashing and the check gauge light was illuminated. Scan gauge showed trans temp of 8124 degrees, factory gauge was sitting at bottom. Did a scan and sg said no codes Pulled over and restarted and all was normal. On my lunch break drove to a store, all was normal, left it idling while I ran in, when I came back out, it was in limp mode again, same deal. Restarting didn't help. Sg still says no codes. Drove back to work in limp mode. It went back to regular for like 30 seconds on the way, then went back into limp mode. Worried about why it's doing this and need help. Truck is the excursion in my sig with about 85k miles.
When not in limp mode it reads normally. Around 155-165 usually. In limp mode, like I said, the factory trans temp gauge drops the needle on the bottom peg, and the scan gauge says 8123 or 8124
YOU HAVE A BAD Tranny TEMP Sensor
A BAD Temp sensor will cause ALL your problems Harsh Shift & Limp MOde
Mine does this to Occasinaly as the truck coming to normal temp once at normal temp its Fine mine would jump to the same 8100* range then drop to 80* then Back up and basicaly ALL Over
Change the temp sensor and you will be fine
Yes SIR You NAILED IT BUD Give this MAN some REP POINTS
TRANNEY FLUID TEMP SENSOR CHANGE WITH PIC
https://www.ford-trucks.com/forums/1...placement.html
Here you go^^^^^^^^^^^^ Now Get it changed LOL
looks like upto 500.00 to have it done
Around 100.00 do it yourself sensor and fluid and probably less
Tousley wants 12.00$$ for sensor cant beat that
Part Number "BC3Z-7H141-A" was found for FORD, but we could not verify the part fits the selected vehicle.
You may still purchase this part below.
Quick Order
Part Number BC3Z7H141A
Part Name SENSOR - TRANS. FLUI
MSRP $19.04
Core $0.00
Online Price $11.52
Quick Order
MSRP $19.04
Core $0.00
Online Price $11.52
