Sponsored by: Real Truck
6.2... Wake up!
Old Aug 5, 2016 | 04:37 PM
  #76
Squisher's Avatar
Squisher
Originally Posted by Spamfritter
Back to the matter at hand. The re-gearing makes a huge difference in how any vehicle accelerates and gave examples of that above. If you don't want to believe that or don't want to take my word for it all you need to do is visit your local dealership. Test drive two of the same vehicle with the same engine and different gearing. You will see a difference on opposite ends of the spectrum. A 3.15 and 3.31 car may not be discernible from one another, but a 3.31 vs. a 3.73 car will be. 3.31 vs. 4.30 in the trucks will be huge. While it's expensive to re-gear, especially if you have a 4-wheel drive its probably the most effective thing you can do short of a supercharger or turbocharger. Not every engine necessarily benefits that much from dropping the cats, replacing the manifolds and changing the exhaust. It all depends on what's there to begin with. I am not sure what the exhaust of the 6.2L trucks looks like as I've never crawled under one that wasn't a diesel. While tuning has a limited effect on most gas engines, I've heard that it does indeed do wonders for the 6.2L.
I'm not sure if your comments are in response to me because you quoted my post. But if so you must of misinterpreted what I posted. I know gearing makes a world of difference I've re-geared a truck from 3.73's to 4.10's. So I didn't have to find two similar trucks to feel the difference, I've experienced it first hand with my '95 that I still own and drive. Until something fails or I can find a used low mileage factory set of 4.3's for a deal, I've got to keep rocking the ridiculously tall 3.73's. I did a dump run today and on the way back I believe the truck was just rounding 65- 70mph shifting into third WOT. Ridiculous.
Also I'm all for customizing trucks however anyone would like to. I'm custom tuned and some exhaust work and imo it makes the truck fun to drive. Crawl under a longbox crew cab 6.2 sometime. You'll find cats, two separate resonators, and a muffler. That's a whole lotta exhaust.
Old Aug 10, 2016 | 07:27 PM
  #77
jtruck618's Avatar
jtruck618
Originally Posted by Poncho450
Count me among those happy with 5 Star. Contact them, tell them what you have & what you'd like it to do. They always got back to me promptly when I had questions.
Got a 2011-2016 6.2L V8 Super Duty? - 5 Star Tuning
Contrary to what Hoss might think, I also did it for an economy tune. But the 87 octane daily tow is nice for the handful of times I do tow every year. A lower gear wasn't in the cards for me because as he says, I don't tow heavy and often. Also contrary to what he says, you'll see me at the funeral home as guest of honor before you'll see a Subaru in my driveway.
As I've posted before, my only complaint is with SCT, not 5 Star. All my devices are Mac. When the SCT needs updating I'll have to send it back or find someone with a Windows based computer.
Do you see any MPG improvements?
Old Aug 10, 2016 | 08:24 PM
  #78
Firekite's Avatar
Firekite
You really shouldn't see any MPG improvements from just a tune in an engine like this one. Responsiveness in shift points or the drive by wire throttle response, sure, even maybe timing adjustments. But mileage is only really going to improve with judicious use of that pedal on the right, restraining yourself from adding any heavy bumpers front or rear and winches and lifting it or putting on oversize tired and all that. Without some fundamental mechanical changes (not exhaust or a replacement intake tube or throttle spacer whatever else) actual fuel efficiency won't be impacted much, certainly nothing outside the margin of error associated with your gas pedal usage and cruising speeds. Even with the placebo effect tempting you to go easy, it would take a very long time for any such tune and tuner to pay for themselves in any tiny MPG increase.
Old Aug 10, 2016 | 08:40 PM
  #79
Poncho450's Avatar
Poncho450
It's hard to say at this point. I really haven't kept close track when driving locally without a trailer behind me. I sold the F450 bucket truck that I'd been towing the business trailer with and have been using the F250 for those duties now.
And I went to the dealer the other day for a TPMS issue so I went back to stock tune. They're waiting for a new BCM so I left it stock for now.
Old Aug 10, 2016 | 08:49 PM
  #80
jtruck618's Avatar
jtruck618
Thanks for the reply. I wouldn't want my mileage to get worse with the tune. Can the tune turn off TPMS?
Old Aug 10, 2016 | 08:50 PM
  #81
GotLift's Avatar
GotLift
I got it tuned and it is definitely an improvement. I have the 86 octane performance tune on it now. I'll try the 91 performance on my next fuel up. I have the 86 octane daily tow tune for towing also. Apparently it is a good daily tune without towing and you get a double benefit with tow/haul mode when towing.
The 86 performance is much firmer in the shifts and the throttle response is better. It doesn't magically make it like a diesel in the lower RPMs, but it is a good compromise for people who don't want the expense of a diesel, especially if it's a daily non towing driver. Happy with this option.
Put Jimmie Jammers on all 4 doors and a lock delete on the driver door today too. These trucks are stolen daily around here.
Old Aug 11, 2016 | 05:52 AM
  #82
Poncho450's Avatar
Poncho450
I don't think you'll lose mileage unless maybe you go with high performance tune of some sort. Although I haven't been a mileage maven, I do notice the better shifts and performance when towing as others have mentioned.
I know that with my 5 Star/SCT device, different tire pressures can be set for the TPMS. I have no idea if you can shut it off. My truck was in the shop 2 days ago for a "tire pressure monitor sensor fault". They said their diagnostic tools couldn't even find a sensor and they had to break down a tire to make sure I had them. I've had this truck from new and the sensors have not been removed. I only had a bigger size tire put on the truck.
So their solution is to order a new BCM. I'm waiting for that to arrive. Personally, I think they're throwing stuff at the wall to see what sticks.
Old Aug 11, 2016 | 09:16 AM
  #83
GotLift's Avatar
GotLift
I switched my wheels and tires off a 2016 F250 to get rid of the "Chrome Clad" plastic and go with aluminum that my cousin had. I didn't even snap that he didn't have the TPMS. That is one option I wish my truck didn't have. Its no big deal to clear the alarm every time I start the truck, but it would be nice to disable the function. I emailed 5Star to ask if they can.
Old Aug 11, 2016 | 09:20 AM
  #84
Poncho450's Avatar
Poncho450
I don't think it's an "option" anymore. I've read on these pages that it's federal law after a certain model year.
Old Aug 11, 2016 | 09:25 AM
  #85
JeepPuller's Avatar
JeepPuller
I do not recommend disabling it or running without TPMS. I'm not a fan of the 'nanny state' stuff either, but I can tell you that during the brief period I ran a set of take off wheels without tpms I picked up something and did not realize it until I 'felt' it. As a result the tire was ruined. It is cheaper to have new sensors installed than it is for a new tire given you need to spend 'time' changing the flat, ordering the new tire, and having it installed. Then, I suspect, the tire place has to install a sensor so you are stuck paying for new sensors AND a new tire.
Your choice, but after my experience, I will opt for the sensors.
Old Aug 11, 2016 | 09:58 AM
  #86
GotLift's Avatar
GotLift
Hmmm? I have the 2015 with TPMS. It gets the fault after I put 2016 factory tires and wheels. My cousin didn't think he had the option, but maybe he just didn't know. Wonder if I have them after all and they need to be calibrated. I didn't bother trying since he said his truck didn't have the option.
Looks like you are right, though. http://www.nhtsa.gov/cars/rules/ruli...nalrule.6.html
Originally Posted by JeepPuller
I do not recommend disabling it or running with TPMS. I'm not a fan of the 'nanny state' stuff either, but I can tell you that during the brief period I ran a set of take off wheels without tpms I picked up something and did not realize it until I 'felt' it. As a result the tire was ruined. It is cheaper to have new sensors installed than it is for a new tire given you need to spend 'time' changing the flat, ordering the new tire, and having it installed. Then, I suspect, the tire place has to install a sensor so you are stuck paying for new sensors AND a new tire.
Valid point. I just didn't want to spend the cash to have them installed. If I already have them then rant over.
Old Aug 11, 2016 | 09:59 AM
  #87
Spamfritter's Avatar
Spamfritter
I'm not really sure how the TPMS compatibility works with regard to the wheels but couldn't you just add TPMS sensors? They aren't that expensive.
Old Aug 11, 2016 | 10:11 AM
  #88
JeepPuller's Avatar
JeepPuller
My belief is they are there. Try to follow the PITA instructions to 'learn' new TPMS. Do not follow the instructions to 'train' the TPMS after you rotate your tires. It is a different set of steps to 'learn' that involves on-off key sequences and brake pedal pushes.
Give it a shot and report back.
Old Aug 11, 2016 | 10:13 AM
  #89
JeepPuller's Avatar
JeepPuller
Of course my assumption is based on your cousin being honest and that he did NOT remove the sensors to use in his new tires. Not saying he did, but I got burned by a person with little integrity on a 'take-off' tire purchase.
The valve stems are a dead give-away; I did not know this when I purchased, but learned it later.
Old Aug 11, 2016 | 10:26 AM
  #90
Spamfritter
If they are factory wheels that are used with vehicles that come with TPMS then they should at least be compatible with the system even if you have to purchase the sensors after the fact. I would just get the sensors rather than disable the system.
