3G Alt Question / Ground
Old Aug 1, 2016 | 01:33 PM
Riskit's Avatar
Riskit
Hello, I'm upgrading the alternator and have a quick question. Do you need to run a dedicated ground off the back of the alternator? All the diagrams show a neg feed but I haven't seen anyone add it in actual pictures. Or does the case of the alternator ground to the block via the way it's mounted?
I have switched out the stock pulleys with a March Performance Serp set-up. Everything is aluminum, does that make any difference regarding the ground and last... I also changed to an aluminum intake. Should I change the location of my stock grounds. Stock I had one from the chassis (fire wall) to the rear of the intake and the negative battery terminal also went to the intake at the coil.
I have all the parts and upgraded wire/fuses but was wondering about the grounds now that everything is aluminum..
Thanks
Old Aug 1, 2016 | 01:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Switching to aluminum won't make any difference, just use some dielectric grease on the terminals to prevent corrosion.
Aluminum is used for the bus runs in power plants now days, especially on the larger units (over 400 mw). Copper capable of carrying that load would be too heavy.
Old Aug 1, 2016 | 01:55 PM
Riskit's Avatar
Riskit
Thanks Mike0,
any word on the dedicated ground off the back of the alternator?
Old Aug 2, 2016 | 06:27 AM
Blue and White's Avatar
Blue and White
As long as the metal case of the alternator is bolted to the block and brackets, no case ground should be needed nor would normally be installed.
If mounts are rubber isolated, the case ground would be needed but not normally the situation with a dent.
Old Aug 2, 2016 | 08:58 AM
hivoltj's Avatar
hivoltj
I painted my alt case so made a small ground strap from the ear on the back to the block. Easy enough. The ear is where a brace bolted to on the Taurus I removed the alternator from
Old Aug 2, 2016 | 09:23 AM
Riskit's Avatar
Riskit
Thanks guys.. I think I just over think it now and then but sure good to have someone else help out..
BruteFord
Electrical Systems/Wiring
May 11, 2016 02:33 PM
LARIAT 85
Mar 14, 2016 04:36 PM
sweet55
Jun 2, 2015 01:34 PM
rustywheel68
Dec 19, 2011 10:35 AM
bob_351
Nov 16, 2007 06:18 PM
