Need help! High idle
Old Aug 2, 2016 | 06:34 AM
Mike Stuckey's Avatar
Mike Stuckey
I have a 79 f150 with a 300 straight 6 and yesterday it started idling really high 2000-2500 I backed off the idler screw and it changed nothing. Would it be a bad gasket or something sticking in the carb?
Old Aug 2, 2016 | 08:21 AM
Filthy Beast's Avatar
Filthy Beast
Check your accelerator linkage/springs/cable from the pedal to carb. Maybe something got boogered up/twisted/broke in that line.
Make sure no vacuum lines are cracked or split around the carb...automatic or manual choke? Either way make sure its functioning properly.
Old Aug 2, 2016 | 09:44 AM
yankeerebel's Avatar
yankeerebel
High idle with no effect from idle screws is pretty indicative of a vacuum leak somewhere.
Just be thorough and check/replace all vacuum hoses first then move on to more subtle spots like carb/intake gaskets, etc.
Mutilator712
16
Oct 16, 2016 08:46 PM
gowild0706
Nov 30, 2012 09:59 AM
siloketh
May 14, 2012 10:58 AM
HoustonGuy
19
May 13, 2012 07:22 AM
old timer
Jun 18, 2000 12:16 PM
