3g alternator- question about ground
Old Dec 19, 2011 | 08:51 AM
rustywheel68's Avatar
rustywheel68
hello-
i'm working on retrofitting a 3g alt onto my FE. there is about 1/16" of clearance between the back of the alternator case, and the cylinder head.
it doesn't look like there will be room to bolt a ground wire into the normal location.
my question...can i just mount a ground anywhere on the case, or is there something special about that bolt hole?
thanks-
Old Dec 19, 2011 | 10:18 AM
Franklin2's Avatar
Franklin2
Normally you do not have to ground the alternator, it grounds through the mounting brackets. If you feel you need a ground, any bolt hole or bracket will do. I have run separate grounds to the alternator on occasion, but that was for vehicles used in the salt for plowing snow, and the mountings were so rusted, the normal ground was no good.
Old Dec 19, 2011 | 10:35 AM
rustywheel68
great- thanks Franklin.
TBerk
Jun 14, 2018 01:45 PM
BruteFord
Electrical Systems/Wiring
May 11, 2016 02:33 PM
mustang81
Dec 29, 2014 08:31 AM
sleddog60
Apr 17, 2009 05:43 PM
grandads76
May 15, 2007 08:50 PM
