p0500 code???
Old Jul 31, 2016 | 02:15 PM
jakesterrocks's Avatar
jakesterrocks
p0500 code???
I've got a 2000 ex limited with the v10.4x4.the engine light came onso I had it sscanned. Also the a.b.s light is on.and the overdrive off light was flashing but now isint.the parts store that scand it said code was po500.told me it's a speed sensor but that there's 3 of them on the truck.so I figured I'd ask to see if anyone has had this code and which sensor it is.
thanks.
Old Jul 31, 2016 | 03:06 PM
afmedic's Avatar
afmedic
When I worked at the dealership, the one that went out the most was the one on the rear end. Not saying for sure that's the problem with yours, but it was common when I was a tech.
Check all of the connectors to make sure they are all connected tight and didn't get pulled out on something. Im pretty sure you can check them with an ohm meter as well but I don't recall the procedure.
Old Jul 31, 2016 | 04:51 PM
jakesterrocks
All wires and connections lookedgood.changed the sensor but check enfine light is still on.abs light went off .is there a way to clear codes?
Old Jul 31, 2016 | 04:56 PM
afmedic's Avatar
afmedic
If you disconnect the battery it'll clear the codes. I'd invest the 20 bucks into the Bluetooth or wireless obd2 readers and download forscan on your computer. Well worth it! All the options that the dealer has for diagnostics!
Old Jul 31, 2016 | 05:03 PM
jakesterrocks
Sweet.thanks.I'll definitely look into that.
Old Jul 31, 2016 | 05:07 PM
afmedic's Avatar
afmedic
Elm327 is the one I have
Old Jul 31, 2016 | 08:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only sensor that can set that code is the one on the rear axle. But the sensor may or may not be the problem. It could also be the wiring to the sensor.
Old Jul 31, 2016 | 09:23 PM
jakesterrocks
I disconnected the battery to clear the codes.the check engine light is off but the abs light came back on.like I said previously. The wiring is all good.
Old Aug 1, 2016 | 08:26 AM
Mark Kovalsky
How do you know the wiring is all good?
Old Aug 1, 2016 | 09:13 AM
jakesterrocks
Cause I pulled it all out of the plastic protective stuff it runs through an followed it .no breaks.cuts or anything.
Old Aug 1, 2016 | 09:22 AM
Mark Kovalsky
And it checked good for electrical continuity?
Old Aug 1, 2016 | 09:27 AM
jakesterrocks
Yes.I'm not go in to spend the time digging through wires and do all the checks .
Old Aug 1, 2016 | 10:02 AM
Mark Kovalsky
OK. Since the wires are good (?) replace the vehicle speed sensor on top of the rear axle.
Old Aug 1, 2016 | 12:07 PM
DidieX's Avatar
DidieX
When the rear sensor went out on my Ex a few months ago the check engine light didn't go on, just the abs light. I don't remember the code that came up though....you might have some other issues. Ps, just because you can't visually see a break in the wire doesn't mean there isn't a break internally. This is very common near the connectors.
Old Aug 1, 2016 | 12:09 PM
DidieX's Avatar
DidieX
This is the scanner I use, picks up all the modules in the Ex:
https://www.amazon.com/gp/aw/d/B005N...pkL&ref=plSrch
buba 11
6.7L Power Stroke Diesel
Apr 2, 2014 02:54 PM
bchez
1997 - 2003 F150
Oct 2, 2010 02:55 PM
pressureelite
1997 - 2003 F150
Jul 13, 2010 10:52 AM
SDW
1997 - 2003 F150
Jan 31, 2004 08:18 AM
EA6B_Pilot
1997 - 2003 F150
Jul 6, 2001 02:52 AM
