Sponsored by: Auxito
Check Engine light
Old Sep 23, 2010 | 07:56 AM
bchez's Avatar
bchez
Question Check Engine light
Used coder to find out that my maf sensor was bad or so I thought. Changed it and reset the light and around 30 miles later it came back on with same code. Sensor was brand new so what else could cause this ?
Trying to sell this truck and so far the only time it was looked at the light was off. I know it will raise alot of questions just need some help.
Old Sep 24, 2010 | 02:57 AM
Bluegrass 7's Avatar
Bluegrass 7
First, nine times out of ten a code does not tell you what part is faulty.
Your first mistake.
What was the code number?
Old Sep 24, 2010 | 05:32 AM
projectSHO89's Avatar
projectSHO89
Your first mistake.
I'd make it ten out of ten.
Fault codes do not tell you what part is bad. The code requires interpretation to understand what failed and what parts may be involved, nothing more.
Old Sep 28, 2010 | 06:42 AM
bchez's Avatar
bchez
I can't remember the code exactly, I borrowed the tester from a friend and would have to get it again. But I can remember it saying that the MAF sensor was dirty, and/or there was a rich/lean running condition. That's all I can remember. Any idea's ?
Old Sep 28, 2010 | 06:55 AM
projectSHO89
Get it read again and, this time, write down the fault code(s).
Old Sep 28, 2010 | 02:55 PM
bchez's Avatar
bchez
Will get the tester tonight. Also now that the light is on the truck will stall out when it kicks down to low idle at a traffic light.
Old Sep 28, 2010 | 05:16 PM
steve(ill)'s Avatar
steve(ill)
code 171 and 174 for example--- MAF OR vacuum leak---- look for small 1/4 inch hoses that are hard and brittle- cracked.
Old Oct 2, 2010 | 02:55 PM
bchez's Avatar
bchez
The codes are 171 and 174, I will check those 1/4 vaccum hoses next.
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
lragan
Nov 15, 2012 12:08 AM
264WSM
Aug 5, 2012 10:45 AM
BadDogKuzz
Apr 28, 2011 07:14 PM
calibob
1997 - 2003 F150
Dec 27, 2008 01:47 PM
