HFCM drain plug upgrade ???
Old Jul 29, 2016 | 12:43 AM
Boomer89's Avatar
Boomer89
New member here. I'm Chris from VA and I just received my upgraded HFCM drain plug from Bulletproof Diesel. I did not receive an o-ring with the product. Is this common or should I be calling them first thing in the morning? Or could I use the existing o-ring from the factory drain plug if still intact/ good working order? Thank you in advance and awesome forum!
Old Jul 29, 2016 | 01:06 AM
87crewdually's Avatar
87crewdually
Should have an oring.
Ford HFCM Drain Plug
Old Jul 29, 2016 | 01:11 AM
Boomer89's Avatar
Boomer89
Thanks 87crewdually. I'll be calling them in the morning.
Old Jul 29, 2016 | 01:51 AM
Yahiko's Avatar
Yahiko
FTE Remembers
If they will do it get some extras. The time before last I had mine open to drain
and the O-ring was a bit beat up and gave aerated fuel after that. Injectors don't
like air. I replaced the O-ring and problem went away.
Sean <BR>
6.0L Tech Folder
Old Jul 29, 2016 | 08:31 AM
Boomer89's Avatar
Boomer89
Thanks for the tip Yahiko.
Old Jul 29, 2016 | 09:25 AM
TooManyToys.'s Avatar
TooManyToys.
I've bought a package of them from McMaster, but still have the original one on the upgraded plug. As long as the O-Ring is lubricated with diesel (hard not to be) and is tightened to snug and not fully compressed they should live a long, long time. It the same with the fuel and oil caps, as a O-Ring they seal under captured compression, not high torque and compression of the cap/plug.
Old Jul 29, 2016 | 12:51 PM
Per4mance's Avatar
Per4mance
Just did it on the Ex,F 250 has been done.Local Ford dealer had it in stock.
Old Jul 29, 2016 | 02:42 PM
Boomer89's Avatar
Boomer89
Thank you for all the feedback! Called Bulletproof Diesel and they said it was an unacceptable mistake. New one has been shipped my way. Replaced my fuel filters and drained the water separator and just replaced factory drain plug for now. Boy were my filters black and the main filter was full of gunk! I purchased this truck a couple of months ago with 45,000 miles and now have 60,000 miles and wish I had changed them sooner! Now I need to replace my fuel return line from the secondary fuel filter housing. I have the part #, but does anyone have a write up for the install?
Old Jul 29, 2016 | 02:45 PM
Boomer89's Avatar
Boomer89
Correction: I need to replace the fuel return line from the regulator on the secondary filter housing.
Mcrafty1
Modular V8 (4.6L, 5.4L)
Jul 5, 2017 08:01 AM
bvieages
May 26, 2016 02:28 AM
RedHorse1
Mar 14, 2016 09:49 AM
Yahiko
Jan 27, 2016 09:59 PM
Ono6.0
Aug 31, 2015 09:23 PM
