rythmic backfire thru the carb
Old Jul 27, 2016 | 05:43 PM
BrushPopper's Avatar
BrushPopper
the magnet gods were good to me, I did get the old lifter out, it was very well worn on the bottom, which worried me... got the new lifter in and whaddya know...... S.S.D.D. rocker still not moving.... guess I will be replacing a cam shaft..
Is there a way that I can shim it up to make it work till I can get a new cam?
Old Jul 27, 2016 | 07:00 PM
BrushPopper
Just found an adjustable rocker off of ebay... and my question is....
Can I just replace the one rocker and still be able to drive my old beast for a little bit, until I can get the parts and the equipment to replace the camshaft?
Old Jul 27, 2016 | 08:10 PM
Tedster9's Avatar
Tedster9
I'm no authority, but it seems to me if the cam lobe itself is lunched, it won't work very well at all, or at least for very long. I'd wonder if maybe it would shed a bunch of sparklies into the rest of the engine, embedding into crank bearings or something. But no idea. Interesting question.
Old Jul 27, 2016 | 10:19 PM
J ballan's Avatar
J ballan
Unfortunatly if the lobe is gone the only fix is replacing the cam/lifters and timing chain. Also a good time to maybe upgrade to a better/more aggressive cam profile. The stock 70s cams left lots on the table. Also don't forget to use some ZDDP additive in your oil if sticking with a flat tappet style cam. Oh and break the cam in properly after. Good luck.
Old Jul 29, 2016 | 10:14 AM
BrushPopper
well, decided, since the cam needs replacing, might as well do a complete rebuild... and since i dont have all the tools and equipment, see attached photo of my shop, got a quote, and found a place that will do it for about $3500
Genuine shadetree mechanic
Old Jul 29, 2016 | 11:24 AM
mountain dewd's Avatar
mountain dewd
Best of luck!
Old Jul 29, 2016 | 11:29 AM
Tedster9's Avatar
Tedster9
Looks like a nice truck. Nice location too. 8k feet in Arizona... Can almost smell the pine trees.
adamdunn86
Jun 23, 2014 01:49 PM
86bullnose
Apr 26, 2012 12:35 PM
Goose_52
16
Dec 20, 2011 08:14 PM
clhart426
Jul 26, 2011 04:29 PM
55Bubba
13
Nov 10, 2004 12:38 PM
