i've got the LSD Diff in my 97' VAN. I know about the LS Additiv, so i bought it for Change.
Before two months i stucked on a puddle of mud which was really tiny. other tire on the street. it wasnt possible to go out, so my self-lock seems to be unable to work.
how does it exactly work? friction-discs?
maybe someone before me Changed the oil without the LSD additiv? what to do then? what to Change?
I don't think an oil change will solve this. Lack of friction modifier can cause grabbing and chattering as you go around a corner because the clutches bite too hard. There are friction discs in the housing that engage when there's a certain wheel speed differential. If they're not working it probably needs to be rebuilt to function again as a limited slip.
A factory LSD is setup pretty loose so In order for it to work there has to be some resistance(traction) at both tires, if there is none at all at one tire then these things operate like an open diff. That minimum traction generates a certain amount of preload on the spider gears which engages the clutch packs and drives both tires evenly. These clutch packs wear with age so it's entirely possible your diff needs a rebuild and maybe a tweak to set it up a little tighter than stock so that it can hold more torque and slip less.
Rockauto sells a rep kit: USA STANDARD GEAR USA16007 Positraction Internals; 30 spline axles; Includes Clutches; Forged Rear; RWD; Dana 60; 30 Spline
€413.18
For that money, I'd interchange it for a TrueTrac.
All options avail. here: https://www.ringpinion.com/DiffWizard.aspx
If you bought diff fluid that had modifier in it and you added the Ford modifier on top of that, you may have to much modifier in the diff and the clutches won't engage. Even when changing fluid without any built in modifier, you're only suppose to pour 1/2 bottle of FM into the diff, that's 3.5oz and then drive it around to see how it acts, if the clutches are grabby, then add the rest.
Yep, LSD require some traction on both tires. I have a FWD track car that i did a diff swap on. There were 2 options. A LSD and a Torque bias. Performance of both are about the same except if you get the inside tire too light in a turn with the LSD, or if you are in adverse weather with one tire on ice. It acts like an open diff. I went with the Torque Bias setup to eliminate this issue.
So if it is normal for the LSD dosnt working with one wheel without traction, I think the whole function of the LSD is Nonsens. this is the Situation while I Need the function
did a lil bornout-start, felt the rear slipping to the right while the tires turn. tells me that the LSD is working, but just with traction?
You can gently apply the brakes or better yet the parking brake to simulate traction on the slipping wheel and improve the limited slip action. Modern cars with traction control can apply a brake on the slipping wheel independently and control throttle to make this happen. I test drove a Sprinter in 2003 before I bought my Ford E150 and put one wheel on ice, the other on pavement, gave it full throttle, and it gently accelerated without wheel slip.
I had put an Eaton posi in my Ford van and it worked great but did chatter a bit around turns on wet pavement--which told me it was working. I never once stuck the van in 13 years and 129k miles. Using LESS LSD additive will increase chatter but in theory improve LSD function.
You can do some google searching on "using brakes to improve LSD" and find more theory on that concept.
The friction modifier additive is solely for use at quieting the noise of the stock LSD. It has nothing to do with its effectiveness or lack there of.
Not correct. The LSD friction modifier makes the lubricant more slippery so the LSD does not "grab" or "chatter". Another application for LSD lubricant is in transmissions in which the lockup clutches "shudder" at a constant speed; some police and taxi fleets have used it as a standard additive in 4R70W's to avoid shudder, and my own trans shudder was fixed using a product called "Shudder Fixx" which is much like LSD additive.
Adding too much LSD lubricant WILL reduce the effectiveness of a friction clutch based LSD unit. Noise is not the issue. You can use a gear lube like Mobil 1 (which has LSD additive) in an open differential with no problems because it will not have an effect on an open differential. However, you CANNOT use Mobil 1 gear lube in a manual transmission (like the one in my Subaru) because it will let the sychronizers (which are cone clutches) slip and gears will grind. I found that Delvac truck gear lube does not have LSD additive and it has been in my Subaru transmission for the last 80k miles. LSD additive is a FRICTION modifier. So if your gear lube already has LSD additive, adding more will probably make the LSD less effective.
@yogeorge
this is really helpful. for sure i dont know whats in but i will Change the fluid and do a Little test ride without the additive. will see.
and i will simulate the ice/brake test
