LS not spinning both tires
Old Feb 25, 2011 | 10:39 AM
ssrider's Avatar
ssrider
I have a 2005 F150 5.4 with the 3.55 LS rear end. I just changed the diff fluid to Lucas 75W140 synthetic and added 4 oz of motocraft friction modifier. The gears looked great when I had the cover off. But now my truck only seems to want to spin one tire. It was on a ice covered road so it shouldn't be that one tire was catching more traction than the other. Could a simple oil change cause the limited slip to stop working?
Old Feb 25, 2011 | 04:02 PM
NASSTY's Avatar
NASSTY
Did the clutches look ok when you had the cover off?
Old Feb 27, 2011 | 05:08 PM
ryan70asu's Avatar
ryan70asu
Could be a few different things... there has to be some traction or resistence on the 1 wheel for it to transfer the power to the other. Applying a little e-brake or brake pedal could help. Also, I've heard that 4oz isn't enough of the friction modifier and 6-8oz is the appropriate ammount. Was the fluid pretty dark when you changed it? Mine was almost as black as dirty motor oil because my cluthces wore out. I now have a Detroit Truetrac in my rear which works way better than the factory units.
Old Feb 28, 2011 | 12:42 PM
ssrider's Avatar
ssrider
Clutches appeared to be okay and oil was actually pretty clean when I drained it. I thought friction modifier made the oil "slipperier" so wouldn't adding more cause even more slip? I had only added the 4oz because the lucas oil says it already has the additive in it, so I didn't want to add to much. But I read somewhere on here to still add the friction modifier with oils claiming they don't need it. I'm wondering if I have to much modifier now and its causing excessive slipping
Old Mar 2, 2011 | 01:01 PM
ryan70asu's Avatar
ryan70asu
Could be the Lucas Oil stuff. Not sure how that works with the Ford LS units. IMO using the factory fluids is the best way to go. I have synthetic in mine now but that's because I got sick of the clutches wearing in the factory LS and had a Detroit Truetrac installed. No clutches.
smashclash
Apr 29, 2010 09:16 AM
ford390gashog
Offroad & 4x4
May 1, 2006 05:40 PM
4wd
Jan 15, 2006 08:03 PM
bimmerbill
2004 - 2008 F150
Nov 28, 2004 09:54 PM
Sycostang67
Apr 13, 2004 04:00 PM
