EGR cooler welding help
Old Jul 24, 2016 | 09:24 PM
jimbo1969's Avatar
jimbo1969
What's a good way to block the ends on my egr cooler I have a stick welder and a mig gas welder I just need a good direction to go in thanks
Old Jul 24, 2016 | 10:17 PM
cheezit's Avatar
cheezit
The best way is tig.
The right way is a bullet proof cooler
Old Jul 24, 2016 | 10:53 PM
jimbo1969's Avatar
jimbo1969
I can not get to a tig will mig or stick welding work
Old Jul 25, 2016 | 02:12 AM
Yahiko's Avatar
Yahiko
Like Cheezit said TIG.
You have to use the correct alloy. It's stainless steel and if you don'e
do it right you will cost yourself more than the BPD cooler would of in
the first place.
Sean <BR>
6.0L Tech Folder
Old Jul 25, 2016 | 07:04 AM
jimbo1969's Avatar
jimbo1969
I'll try and find someone to tig it
Old Jul 25, 2016 | 11:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
MIG is perfectly fine. Use at least 3/16" plugs. Mild steel is fine with ER70s-6 and C25 gas.
Intake side plug is about 29mm and the exhaust side is 35mm.
Josh
Old Jul 26, 2016 | 09:28 AM
jimbo1969's Avatar
jimbo1969
Thanks I'll try that
Old Jul 26, 2016 | 09:37 AM
Tideman's Avatar
Tideman
Jimbo, I dug around my shop and found a piece of 1/4 stainless had it cut and welded in both sides. Works great. Look at how your ends are and fit inside carefully.
Old Jul 26, 2016 | 10:03 AM
jimbo1969's Avatar
jimbo1969
I'm going to replace the oil cooler this weekend and I wanted to weld up the egr cooler why'll I had it out I have a good gas mig and I can weld pretty good so I'm going to give it a shot
Slowe
Jun 22, 2016 09:40 PM
mkingz
May 9, 2016 08:32 PM
Yahiko
Mar 29, 2016 09:23 PM
joeinca
Feb 24, 2016 05:11 PM
geeride
Sep 21, 2015 08:17 AM
