Vgate ELM327 Scan tool?
Old Jul 24, 2016 | 04:56 PM
xaviar's Avatar
xaviar
Has anyone used this device to trouble shoot their truck? Injector buzz test etc....
Seeking feedback if it's really worth it..
Watch "How to Buzz Test 1996-2008 Ford Powerstroke Diese…" on YouTube
How to Buzz Test 1996-2008 Ford Powerstroke Diese…:
Thx
Old Jul 24, 2016 | 05:12 PM
87crewdually's Avatar
87crewdually
I do have that app. I got it to work once. It is a pain going through everything to get to that point of the test.
Old Jul 24, 2016 | 08:36 PM
xaviar's Avatar
xaviar
Yeah, that's what this guy was saying in the video. Found it interesting if it actually works correctly and is accurate?
Old Jul 25, 2016 | 05:25 AM
WatsonR's Avatar
WatsonR
Use ForScan, easier to use, does more stuff.
Old Jul 25, 2016 | 09:08 AM
xaviar's Avatar
xaviar
Hi Randy, what adapter are you using? Seen so many different ones and complaints on certain ones.
Thx
Old Jul 25, 2016 | 09:31 AM
WatsonR's Avatar
WatsonR
http://cgi.ebay.com/ebaymotors/ELM327-USB-Interface-OBDII-OBD2-Diagnostic-Auto-Car-Scanner-Scan-Tool-Cable-/322064603508?hash=item4afc8bd974
Its faster than the blue tooth version and easier to configure. Plug it in, turn on the key, start Forscan. Don't load the CD that's provided, it's full of spyware.
Old Jul 25, 2016 | 09:53 AM
xaviar's Avatar
xaviar
Thx, appreciate it.
Old Jul 25, 2016 | 09:57 AM
WatsonR's Avatar
WatsonR
remove the FICM relay if your going to play with it. Most tests are KOEO, buzz tests and a bunch others. The new version is supposedly doing contribution type tests, can turn injectors off.
Old Jul 25, 2016 | 11:06 AM
xaviar's Avatar
xaviar
OK thx. I C there are 2 versions of forscan. A lite and a Demo. Which one are you using? Is the demo the full version ?
Thx, again.
Old Jul 25, 2016 | 11:16 AM
WatsonR's Avatar
WatsonR
I think that Lite is for an Android phone and it's like $5 from the Google store. I just down loaded that a couple weeks ago before heading to Bahrain. I'm going to try it with a blue tooth ELM327 when I get home next week.
Down load the demo and use Forscan.org for the site.... think its at 2.3.1 beta
Old Jul 25, 2016 | 12:23 PM
Euroman's Avatar
Euroman
I use forscan with the iPhone and elm327 and it works great, just make sure it's the only wifi around and it connects straight away, otherwise the iPhone goes looking for one with an Internet connection. It was $5 as well, and well worth it 😀
Old Jul 25, 2016 | 01:26 PM
xaviar's Avatar
xaviar
Thanks Randy and Euroman. I'll be ordering the adapter today. Just downloaded the apps.
Old Jul 25, 2016 | 02:03 PM
diesel_dan's Avatar
diesel_dan
Hey Randy: just a question on your adapter as I've been thinking of getting a second hard-wired one, for security purposes (one of the reasons I stuck with BT over WiFi was distance limitation), back to the question: does it also power your phone, ie. provide a 5V charge supply on the USB?
Old Jul 25, 2016 | 11:07 PM
87crewdually
That adapter USB plug is the large end for a laptop. It will not plug into a phone. The eBay link ad shows it in the last picture.
Old Jul 25, 2016 | 11:52 PM
WatsonR's Avatar
WatsonR
This is correct... it's USB, not mini-usb. BUT, I saw, a couple days ago a mini-usb adapter that went from USB>Mini-USB and I'll pick one up and see if this will work plugged into my phone. Unfortunately, I'm in Bahrain and will be home early next week.
wackercattle
Aug 25, 2013 10:06 PM
bebeard
Aug 21, 2011 05:35 AM
adamzelazowski
May 26, 2009 07:28 AM
caseydudem
Jan 1, 2008 11:40 AM
97 HD
Oct 23, 2007 06:24 PM
