Buzz test sequence??
Old Aug 24, 2013 | 11:36 AM
wackercattle's Avatar
wackercattle
What sequence does the buzz test use while buzzing the injectors? Mine seems to jump around.
Old Aug 24, 2013 | 11:40 AM
ReBilld's Avatar
ReBilld
The sequence is 1-2-3-4-5-6-7-8. The cylinders are 2-4-6-8 front to back on the driver side, and 1-3-5-7 front to back on the pass. side.
Old Aug 24, 2013 | 11:53 AM
glovemeister's Avatar
glovemeister
The buzz test will fire every injector then it will jump around from bank to bank.
Old Aug 24, 2013 | 12:08 PM
wackercattle
Okay thanks- I hear the second buzz (after they all buzz together ) sounds flat, but it's on the passenger side. Have to get the stethoscope out.
Old Aug 24, 2013 | 12:56 PM
glovemeister
The individual injectors are rather quiet it seems like. But if something is way obvious then it may warrant further investigation.
Old Aug 24, 2013 | 08:37 PM
fordpride's Avatar
fordpride
On buzz test it fires all 8 first the 1,2,3,4,5,6,7,8
Old Aug 24, 2013 | 10:35 PM
wackercattle
I turned the radio off and got real quiet- the second buzz was really faint, it was the drivers front. Seems weird I keep getting the P01271- number one cylinder circuit open. Tomorrow I will pull that side valve cover off, I got a few injectors used today.
Thanks again!
Old Aug 25, 2013 | 10:04 PM
wackercattle
Okay- I pulled out old number two injector and whatdoyaknow- looking at the plug end I only saw one terminal, the yellow wire was pulled through. It must have been making just enough contact to pass the continuity check but not enough to fire the injector properly. I fixed the wire and installed the fresh injector anyway since I had it.
I re-ran the buss test, all 8 sound consistant, the truck runs sweet, but the p1271 code is still there- weird....
Thanks for all the support!
Old Aug 25, 2013 | 10:06 PM
ReBilld's Avatar
ReBilld
Good deal!
Christof13T
19
Jun 20, 2013 05:17 AM
caseydudem
Jan 1, 2008 11:40 AM
97 HD
Oct 23, 2007 06:24 PM
mtgrzlyman
18
Sep 6, 2006 10:04 PM
Craze
Feb 17, 2006 12:46 PM
