makeing a firewall brake mount
Old Jul 24, 2016 | 09:40 AM
#1spudman's Avatar
#1spudman
need help to make a firewall brake mount
Old Jul 24, 2016 | 11:05 AM
sparky's Avatar
sparky
Well the way I made it roughly from memory it was a while ago, which may or may not be correct, was:
I got a hanging brake pedal and bracket from a 90 Tbird.
Set the bracket where I wanted it on the firewall so the pedal set where I thought it should be.
Used the bracket as a template to drill the mounting holes for the bolts, think there were five of them.
Then drilled a hole for the centre of the booster to fit thru the firewall, and tightened it down. The booster was from a 1988 Mustang so I had to adjust the mounting holes a little.
Also added a mount from the firewall to the dash so the firewall wouldn't flex when the brake was pushed.
That is it in the proverbial nutshell, hope it makes sense.
Old Jul 24, 2016 | 01:52 PM
jniolon's Avatar
jniolon
old and in the way
sparky told you right... here's some pics that might help
http://www.fordtruckzone.com/threads...-f-100.655090/
http://jniolon.classicpickup.com/plu...iscbrakes.html
john
Old Jul 25, 2016 | 05:27 AM
mike.rogers's Avatar
mike.rogers
I have a clutch / brake mount from a 70 ford f100. Your more than welcome to it if you think you could make it work. Not sure what shipping would cost you, but you can have it if you want it
mike
Old Jul 25, 2016 | 04:13 PM
#1spudman's Avatar
#1spudman
thank's all of you for all your help that is what im was thinking i wish there was a thread here for the rat rod ford's here too my is a1951 f3 keeping it all ford is what i have ben doing but thanks a gin for all the help keep up the good work spudman out
Pappys53
Jan 16, 2019 05:47 PM
davbell22602
Oct 12, 2011 03:31 PM
Björn
Feb 26, 2011 06:20 PM
atlantaf100
Oct 10, 2001 12:18 PM
