Has anyone used CPP's firewall mounted brake bracket? It looks like it is not as massive as the one from Midfifty.if Midfifty's better? I am working on my 53 f100 pu.
Not exactly understanding what you are saying? The picture I saw online of CPP bracket looks different from Midfifty's. So who are you saying supply to the other one?
Yes CPP is the supplier for Mid fifty.
the picture on CPP's link shows 2 different bracket assys. the one on the right is for the 48-52, and is smaller.
The picture on eBay showing CPP's looked different that is what prompted my post. I have not been able to find just the bracket on their web page. I just want the bracket and pedal arm
That link for CPP I believe is what you are asking for Pappy, bracket and pedal, it's $149. If you purchase it with the booster and master cylinder, proportioning valve it's $299 They just use the same picture for description. Give them a call and tell them what you're after. Might be better going with the complete package rather than using used parts
Hey bjmaybery2 I picked up a cab in great shape it does need some finish work done and a few holes need welded up. Not what someone was thinking. Been too cold here to do much on it my garage is not heated. Going to pick up some things I will need to put it back together once I get the cab done. I need some inner fender wells. Going to try and repair the fenders and the valance
