power brake question
Old Feb 26, 2011 | 01:29 PM
Björn's Avatar
Björn
Can you fit this set in a ford f100 1956
Someone has ever done that Power brakes FORD TRUCK 1957-1972, F-100, F-250 CHROME - eBay (item 330533709333 end time Feb-28-11 08:44:25 PST)
Old Feb 26, 2011 | 05:20 PM
sdetweil's Avatar
sdetweil
Originally Posted by Björn
it is a firewall mount kit,so yes,you can make it fit.
I have a slightly larger booster and sized master hanging on my firewall..
I don't know if that is the right bracket however. the one I used bolted between the firewall and the dash to provide some additional firewall stability (as it will flex when you step on the brake otherwise)
Sam
teardropty's Avatar
teardropty
Email the seller directly. I have dealt with him on a lot of brake setups and he is great about tech support and knowing what is what. If he says it will work, it will work. Good luck.
Old Feb 26, 2011 | 05:29 PM
Björn's Avatar
Björn
Sam
Do you have a picture of the booster on the firewall Sam
Old Feb 26, 2011 | 05:47 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Bjorn,that unit is what I have sitting on a shelf,for a future project.It uses a smaller vacuum unit and is designed, along with the extending bracket ,for trucks that have the firewall mounted brake and clutch master cylinders.The bracket/smaller booster are necessary because of how close the clutch and brake master cylinders are.And teardropty is right,that guy,IrishDave is great to work with.Contact him with your exact info,and he'll sell you just what you need.
Old Feb 26, 2011 | 05:48 PM
sdetweil's Avatar
sdetweil
there is a section in my gallery on installing the fw mount booster and hanging pedals..
and here is a recent pic, best I have at the moment..
sorry for the sunlight
Sam
Old Feb 26, 2011 | 05:54 PM
Björn's Avatar
Björn
Oke thanks for the info
Sam
Sam where did you buy it
Old Feb 26, 2011 | 06:20 PM
sdetweil's Avatar
sdetweil
the hanging pedal arm, and booster were bought separately from ebay.
the master is the new chrome MCP booster from classic performance products
I like this master cylinder cause it has a built-in adjustable proportioning valve, and a brake light switch port too.
Sam
dsrtjeeper
18
Nov 4, 2013 01:12 PM
hotfalcoon
Mar 31, 2012 03:00 PM
mainefrenchman
35
Feb 16, 2011 12:04 PM
richabilly
Dec 15, 2009 04:55 AM
Fomoko1
Jan 23, 2007 07:50 PM
