what am i missing
Old Feb 19, 2011 | 03:20 PM
first rebuild's Avatar
first rebuild
what am i missing
i have a 51 f1 truck flat head engine i cant get running i have changed to 12volt neg ground with alt. i have the starter hooked to the relay and bat. now i need to hook the coil in there is a i and s on the relay the s I had hooked to the key switch to engage the starter. were do i hook the + and - sides of the coil to this so it will fire previous owner had cut out the wiring harness disassembled the carb the desided that it wasnt what he wanted and sold the truck to me. I cant tell whats missing just trying to start the engine help
Old Feb 19, 2011 | 07:58 PM
Old F1's Avatar
Old F1
Welcome to the site!
Where is that damn Julie when you need her??
OK.
I think you will need a 12 volt coil.
As you have done, the S terminal on the solenoid is to send battery power via the big cable to the starter and is activated by the start position on the ignition switch.
Power (12 volts) goes to the + terminal of the coil from the ignition side of the ignition switch. (Different from the accessory terminal so that the points are only energized when running) Because 12 volts will burn the points you will have to install a ballast resistor (cuts the points back to around 6-8 volts) in the wire from the ignition switch to the + terminal on the coil.
The I terminal on the solenoid is a 12 volt by-pass that sends 12 volts to the coil when starting / cranking so that starting is better and is also attached to the + terminal on the coil.
The – terminal on the coil goes to the distributor (points).
Clear as mud, huh?
Someone has a picture and will hopefully post it.
Old Feb 19, 2011 | 08:40 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51
I got this from one of julies threads...
I forgot how to post it on a thread though
https://www.ford-trucks.com/forums/p...ictureid=61141
Old Feb 20, 2011 | 02:49 PM
Old F1's Avatar
Old F1
From the crypt; Ghost Wiring diagrams (don't ask)
https://www.ford-trucks.com/forums/9...he-engine.html
Phlanx
Sep 7, 2013 10:53 AM
dcraig1000
Apr 17, 2012 05:53 AM
strokerfe
Sep 28, 2011 04:41 PM
Dragracer_Rob
Apr 15, 2009 09:11 PM
LARIAT 85
May 25, 2007 10:49 AM
