Lifter help
Old Jul 21, 2016 | 10:13 PM
Oldschool2888's Avatar
Oldschool2888
Lifter help
I need to collapse lifters on a 390 with non adjustable rocker arms. It is necessary to collapse lifter to check correct push rod length. What method should I employ. Thanks Jerry
Old Jul 22, 2016 | 12:23 AM
tbm3fan's Avatar
tbm3fan
I just finished this. You need the appropriate pushrod checker. A good set of feeler gauges. A pair of channel locks to use for applying pressure to bleed down the lifters. I set my pushrod checker length to 9.570" feeling that nothing would be less than that. Put the checker in place, pry the rocker back to bleed down the lifter, and hold while using the feeler gauges to see what the clearance is. Several articles said to add those numbers and then subtract 0.05" to get you pushrod length.
Cman8469
May 18, 2020 12:57 AM
wagonerkl
26
Jul 25, 2011 10:03 PM
wagonerkl
Apr 15, 2011 05:52 PM
73 fourxfour
38
Feb 20, 2011 02:55 PM
2020
Mar 9, 2010 09:12 AM
