Ignition Problems 66 240
Old Mar 16, 2004 | 12:00 PM
bobg's Avatar
bobg
Unhappy Ignition Problems 66 240
I just rebuilt the 240 in my F100 and got everything set , tried to fire her up but I am getting no voltage to my coil. The motor spins
, distributor and points check out. I am not getting voltage at the
wire(red) attaching to the + terminal of my coil. Does anyone have a way to trace this or have had the same problem. The ignition is stock(points and condensor). The ignition worked fine before I pulled the engine! Appreciate any help
Old Mar 17, 2004 | 10:22 PM
cdherman's Avatar
cdherman
Well, fer starters, a wiring diagram is pretty handy for these old gals. You may want to order one -- lots of places have them, eBay, Obsolete, LMC etc etc.
Is that red wire actually a red wire with a green stripe? The 65 wire is red-green to the plus side of the coil. If you have no voltage to the plus side of the coil, then it don't matter what is going on with your points etc -- you got no spark. Period.
My first guess -- go over to the firewall and make sure that the main connections are good -- a little dielectric grease, used SPARINGLY on each of the terminal is a good idea. If that doesn't work, then go over to the switch in the cab and make sure that the pink wire coming back from the firewall is attached.
By your description, you have no fire when you are cranking. You actually should have about 6-8v to the coil whenever the ignition switch is turned to "on". When its all the way over to start, such that the solenoid enganges, there is a special separate circuit that gives 12v to the coil while cranking. This second circuit attaches to the solenoid on the starter lug side. On the battery lug side there will be another wire coming from the switch, which is engaged obviously only when the switch is all the way in the start position.
In any case, IF you never have any voltage at all, whether you are cranking, or just sitting there, then you almost certainly have either a wire that is interupted between the coil and the firewall, OR it is shorted. If it is sorted, I'd think it would have burned the crap out stuff and you'd have noted. Its a non-fused circuit, I believe.
Hope this gets you started. Post back with more info.
Old Mar 17, 2004 | 10:26 PM
FTE Ken's Avatar
FTE Ken
http://www.motorhaven.com/customer/home.php?cat=114
and I'm fairly certain two other site sponsors have it as well:
www.macsautoparts.com
www.autokrafters.com
Old Mar 23, 2004 | 09:56 AM
bobg's Avatar
bobg
I got a hold of a wiring diagram and found that he wires from the ignition to the coil was shorted. Runs great now ! Thanks for the great help. !!!
jxnslotcar
Apr 23, 2013 07:24 PM
rustywheel68
Electrical Systems/Wiring
Mar 20, 2013 08:26 AM
TheSkycrane
Dec 16, 2012 12:17 PM
redthhies
Apr 9, 2010 09:25 AM
DrFord
May 10, 2002 11:23 AM
