2012with 199k
Old Jul 15, 2016 | 08:44 PM
fordboy2's Avatar
fordboy2
2012with 199k
Looking at 2012 ccsb 4wd with 199k on it. I've had 6.0's and lots of 7.3's. What should I be looking at on his truck? Should I shy away and just keep the 7.3?
Old Jul 15, 2016 | 09:45 PM
Just Strokin's Avatar
Just Strokin
One thing I would do it get the VIN and take it to a Ford dealer service dept and ask them to print you an Oasis report. It will identify any work Ford did to the truck. I would also pay for a CARFAX on the truck with this many miles. See what it reports. It it has the center display, check the engine hours and the idle hours to see what percentage idle time it has.
Personally, unless it was hell of a bargain, I would shy away.
Old Jul 15, 2016 | 11:00 PM
UGA33's Avatar
UGA33
If it's clean and priced right, I say have at it. Bunch of high mileage 6.7s running around. 2012 will keep you out of valve issues. There is a 2012 KR for sale locally with 315k miles. Guy wants $26k for it....
If you get the price right and want TRUE piece of mind, swap the CP4 HPFP out for a new one. That way you know it will be right. For what they do, they are actually fairly cheap IMO.
Old Jul 16, 2016 | 05:49 AM
senix's Avatar
senix
I'd be checking to make sure all the fluids have been serviced, differentials and transfer case get over looked a lot.
How about the front suspension? 4x4 ***** turn easy?
Check the radiator seams on the side to see if there are any leaks.
All diesel since 2008 model year are prone to leak down by the drivers side.
Old Jul 16, 2016 | 06:08 AM
ruschejj's Avatar
ruschejj
I sold the 2011 F-250 I had for $22k in a matter of hours. It had 240,000 but there was a 2012 engine installed in it. I sold it in 2014. The only issue the new owner has had was that the sunroof slide mechanism self destructed leading to a $900 repair. I could find out but I estimate that the truck has over 300k on it now.
These trucks can last a long time, just do what you can to learn the history and make sure it hasn't been abused.
Old Jul 16, 2016 | 12:38 PM
fordboy2's Avatar
fordboy2
It has a clean car fax and is 2 owners. But by looking at the Carfax I almost think it was the same owner. Body is straight with no damage or scratches. They want 19900 for it. About due for tires soon. Which isn't a big deal since I have set from another truck I can throw on it. Optioned out really nice for an xlt.
Old Jul 16, 2016 | 01:04 PM
69cj's Avatar
69cj
If it's a dealer and you like the truck, try 19 grand out the door. They'll probably still make a profit. Also, is the PO local so you can talk to him. Worthwhile even if long distance. Don't know if that term even applies with todays cell phones.
Old Jul 16, 2016 | 01:22 PM
fordboy2's Avatar
fordboy2
No there not local, the truck is from Canada and was bought at the auction. When I go drive it is there anything in particular on the motor I need to be looking/listening for other than the radiator issue? I pretty confident in checking the rest of the truck as I've had quite a few superdutys. But not familiar with the 6.7.
Old Jul 17, 2016 | 09:59 PM
fordboy2's Avatar
fordboy2
I came across a 2012 with 158k today that I emailed the dealer about. Plus its a long box which better fits my needs. 6 hours away but if its a better set up I.ok with the ride. And its a 1000 cheaper asking price. Still looking for any tips when I look at it.
Old Jul 18, 2016 | 04:59 AM
senix's Avatar
senix
just lots of visual inspection is all I can suggest.
I would really get on the ground and make sure all the exhaust components are intact and looking good.
Old Jul 18, 2016 | 05:44 AM
fordboy2's Avatar
fordboy2
The exhaust is a good idea. Is there a certain point where any of those components need replacing? Like an average mileage range or anything? A way to tell if it's doing the regens like its suppose to?
Old Jul 18, 2016 | 06:57 AM
elee3's Avatar
elee3
I'm not sure if there's a way to assess the condition of the DPF, but that would be good information to have.
Old Jul 18, 2016 | 08:44 AM
senix's Avatar
senix
There really is no way in assessing the DPF. Although if it is cleaner then the rest of the exhaust then the truck may have been tuned.
If the exhaust is black then the dpf maybe cracked and needs replaced.
cv67cheng
6.7L Power Stroke Diesel
Mar 22, 2019 10:54 AM
fordboy2
6.4L Power Stroke Diesel
17
Oct 31, 2014 07:42 PM
itsacummins
Mar 31, 2012 07:41 AM
btacarlton
Jul 22, 2011 09:46 PM
mgraveman
May 31, 2004 06:27 PM
