No start no crank
Old Jul 16, 2016 | 07:43 PM
  #46
BLADE35's Avatar
BLADE35
I would agree^^
sounds like he hears a lot of air thru the oil filler tube
Old Jul 16, 2016 | 08:14 PM
  #47
cookingguy's Avatar
cookingguy
Got it put half way back together. Just enough to get the icp sensor back in and hook up a few other items. Didn't put my turbo back yet. But I did get the icp pressure to go up and the ipr %was at 24.5. so I got a little carried away with seeing the pressure go up and then boom it fired I run in the tuck pull the key. Well let's just say a big gulp cup under the turbo oil supply does not really catch all the oil u think it would in the split second that the tuck was running icp was at over 4000 psi when I cranked. Well it's a mess all around where the turbo goes, but I hope truck should be good for a bit I hope. Oh ya the fix. Well I Checked the entire oil rail all the o rings everything check all injectors on the passenger side all was good . So i the one thing I could think of was my awa fitting was just a bit loose, so I got my 3 foot breaker bar and tightened the **** out of it. I will complete my reassemble in the morning. My neighbors must think I am totally nuts with all the screaming over the last few days.
Old Jul 17, 2016 | 08:29 AM
  #48
BLADE35's Avatar
BLADE35
Sweet bro
you needed a break for sure
Old Jul 17, 2016 | 08:54 AM
  #49
cookingguy's Avatar
cookingguy
Originally Posted by BLADE35
Sweet bro
Yes I do, four days on this dam truck is to much.
nighthawk285
Aug 3, 2019 08:08 PM
kylant
Apr 23, 2017 03:48 PM
bbathey25
Aug 23, 2016 10:45 AM
devovino
Nov 16, 2015 04:08 PM
Lost_Arkitekt
Oct 25, 2009 05:53 PM
