I don't think it leaks other then you blown all the oil out the system and air may escape since it not sealed by oil
and you certainly cant base it off ICP and IPR readings since you have P2285 and that an electrical circuit error DTC
this truck will not run until the DTC is resolved IMO and its not throwing a P2285 over a Leak you would have a different DTC altogether for a leak (or should)
Could the 2285 be there from you unplugging the sensor would be the only catch here if you have cleared the DTC and plugged the sensor in and it still returns the circuit needs trouble shoot it continuous monitor so the CEL should turn off upon a Fix
Ok so I cleared the code numerous times. Will try again. My icp voltage when key on and engine off is at 0.11 is this the right voltage? It does not appear to change when cranking
So I cleared the code it has not come back up. I had a damaged wire under the loom I found repaired itcode. is gone. Charging my battery's again and will try to purge the air and go from there.
So when I crank the engine and I have the icp removed from the port no oil comes out at all. Shouldn't there be some oil shooting out of the hole where the icp goes
I have nothing co.ing out. Could I be looking at a hpop? Before all this started when I would go to start the truck I would get anywhere from 1500 to1700 psi showing on the icp reading. I would think that's pretty good.
