Sponsored by: Real Truck
Trans Temp gauge
Old Jul 15, 2016 | 02:19 PM
Medline's Avatar
Medline
Trans Temp gauge
Been searching forever, even googling.. Can't seem to find a straight forward answer...
Can you use the wires already used on the stock cluster on an aftermarket temp guage? Will it read accordingly? Would like to see the actual temp and not the "50-5000000" range ford has em at..
Otherwise I'll just run new equipment, just wanted to know if this would shave time off the job without sacrificing accuracy..
Old Jul 15, 2016 | 02:27 PM
Long Haul's Avatar
Long Haul
I can't answer your question for sure one way or another, but I will say an external trans temp gauge is real easy to install if you choose to go that route..
Old Jul 15, 2016 | 02:29 PM
Medline's Avatar
Medline
I take it if it's not possible, I can just place a new sensor in the old sensors place?
Gimme those... pweeeeez
Old Jul 15, 2016 | 02:39 PM
Long Haul's Avatar
Long Haul
I used the test port on mine..
Just pull the plug and thread in the sensor that came with the gauge..
Old Jul 15, 2016 | 02:41 PM
Medline's Avatar
Medline
Seems like that's what everyone recommends. Unless I can get a legitimate answer I'll just be doing that. Appreciate it Long Haul
Old Jul 15, 2016 | 02:46 PM
Long Haul's Avatar
Long Haul
Sure thing bud, sorry I couldn't give you a definite answer to your question.
Old Jul 15, 2016 | 02:55 PM
Chuck's First Ford's Avatar
Chuck's First Ford
unless you plan to cut out the wires going into the computer.. NO.
install new wires to the gauge.. EASY.. power, ground, signal from sending unit.
BUT I am assuming you have a computer controlled engine.
NO information on what you are driving.
Old Jul 15, 2016 | 02:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You cannot use the stock sender. The stock sender is connected to the PCM. The PCM uses the data to calculate a temperature. The PCM sends this information to the dash computer, and that computer determines where the needle points.
If you replace that sender the PCM is going to detect an error. The OD OFF light will flash, codes will be stored, and the trans won't operate properly.
Old Jul 15, 2016 | 03:00 PM
Medline's Avatar
Medline
That's what I was looking for. It's an 05 6.0 so I'll just run new equipment. Thanks Chuck
Old Jul 15, 2016 | 03:03 PM
Chuck's First Ford
Please read the above statement from a Ford transmission expert... Mr. Kovalsky
deeper than I thought...
if you plan to Run an aftermarket gauge.. using the stock sending unit to match threads.. and purchase a "T" and run both.
but you may need several adaptors.. as the Ford sending unit and the aftermarket sending unit most likely are not the same thread or size.
Old Jul 15, 2016 | 03:20 PM
Medline's Avatar
Medline
So if I use the test port I just basically have to run everything and find power, right?
Any chance I can screw things up by buying a single guage and it not having the correct threaded pieces?
Old Jul 15, 2016 | 04:22 PM
Chuck's First Ford
NO, not wiring the "T" is a threaded "T" to thread in sending unit... so 2 senders can use the same threaded hole in transmission. and stock sending unit to stock wires.
and aftermarket sending unit to aftermarket gauge.. if you still want one.
do NOT connect anything to factory stock wires for transmission.
Old Jul 15, 2016 | 04:55 PM
Mark Kovalsky
Uhhhh, no.
The stock sender is inside the pan. It doesn't have threads, it has a plastic piece that pushes in place to hold it.
The test port is on the driver's side of the trans. It is a 1/8" NPT thread, which is what 99.9% of the sending units are.
Old Jul 15, 2016 | 05:00 PM
Medline's Avatar
Medline
Originally Posted by Mark Kovalsky
Uhhhh, no.
You're a god. Thanks for the feedback, Mark and Chuck
JPs2003
Aug 25, 2010 11:12 AM
shark1979
Aug 3, 2009 11:23 PM
n0tst0ck
May 28, 2004 03:03 PM
ThePheonixx2
Oct 17, 2003 03:10 PM
