No hot start code p2285
Old Jul 13, 2016 | 02:24 PM
cookingguy's Avatar
cookingguy
So I had a bit of trouble getting my 2006 f250 to start after letting it sit for a few minutes then going to start it. It did start after a few cranks. checked my scangauge and I was getting code p2285 low circuit. Got home checked the icp harness ( I replaced the icp and harness about 1.5 years ago). All the connections looked fine. I let the truck cool down over night come out in the morning it fired right up. So took my wife to work and come home shut down the truck, went to start it back up and no go, my scanner told me my icp was at 350 or so. I disconnected the icp and still no start. I run an air test. When removing the icp I noticed the rubber washer under the valve cover is damaged and a little bit of oil is leaking out. So i am doing the air test and when I command the ipr closed ( this is before I turn the air on) I can hear noise coming from what sounds like the oil filter housing. So I turn on the air and I i hear air coming out from where the air hose screws into the icp port. still hear the noise from oil filter housing. I put it all back together and I go to start it to see what happens and my icp is reading 0 and does not change when cranking. Any ideas would be great. Thank all
Old Jul 13, 2016 | 02:56 PM
WatsonR's Avatar
WatsonR
Have you done the STC fitting yet?
Old Jul 13, 2016 | 03:16 PM
cookingguy's Avatar
cookingguy
Stc was the first this i had to the truck two years ago
Old Jul 13, 2016 | 04:06 PM
Macrosill's Avatar
Macrosill
When the icp was 350 what did the ipr read? 84%?
I would pull the oil filter and cap and visibly look for air coming from the oil filter housing. I would also pull the valve covers to check under them visually, especially since you have to pull one due to a leak anyway.
Old Jul 13, 2016 | 04:08 PM
cookingguy's Avatar
cookingguy
So I just did another air test with the passenger side valve cover off and air is pissing out of somewhere under the rail I can't feel the air at all just hear it. I have all new injectors,dummy plugs,stand pipe and ball tubes/ nipple cups. Any ideas when I say new i mean every part mentioned is at least two years old or newer
Old Jul 13, 2016 | 04:11 PM
Macrosill's Avatar
Macrosill
Keep looking. It is under there somewhere. Use a mirror to look. You may have better results by taking some oil and pouring it in the area of the air, you should see it bubble or spray away from the source.
Old Jul 13, 2016 | 05:46 PM
cookingguy's Avatar
cookingguy
So I felt the air leak it's either the awa fitting or a nipple cup o ring. I think. The awa fitting o ring does not look to bad but it does look a little flat not sure how to tell 100% if it is that or not
Old Jul 13, 2016 | 08:29 PM
WatsonR's Avatar
WatsonR
They are cheap, replace all the nipples cups o-rings and retest. That don't work, do the injectors seals or just do them all. Not surprising, they are a wear item, I expect it every two years.
Old Jul 14, 2016 | 08:19 AM
cookingguy's Avatar
cookingguy
All the nipple cups and nipple cup o rings are maybe 6 to 7 months old
Old Jul 14, 2016 | 08:50 AM
Tideman's Avatar
Tideman
A slight twist or a small nick in a "O" ring may take months to show up. (Ask me how I know) when you have the symptoms that you have (can hear air coming out, 0 ICP, no crank) you're going to have to go in there to find it. Although I am surprised at the 0 ICP. Usually it will show something. Also using off brand "O" ring and seals will go out earlier.Remember you've 3000+ psi pounding on them.
Old Jul 14, 2016 | 09:38 PM
cookingguy's Avatar
cookingguy
So this morning I did some more investigation and found an injector o ring,the inner one where the nipple cup goes in was damaged. Installing the new injector in the morning. I will update then.
Old Jul 14, 2016 | 09:43 PM
Tideman's Avatar
Tideman
Just curious as to why you're installing a new injector when it's the "O" ring. And usually when ones bad the other "O" rings are not that far behind.
Old Jul 15, 2016 | 08:14 AM
WatsonR's Avatar
WatsonR
And that kit only costs $6 and 10 minutes to change all the o-rings on an injector, including the top seal.
Old Jul 15, 2016 | 03:14 PM
cookingguy's Avatar
cookingguy
My parts guy just did a warranty on the injector. But the new issue I got it all put back together and now my scanner will not connect to the system and the wrench lite is on. Turn the key and nothing. Battery's have a full charge. I can get it to crank when I jump the starter wire to the positive on the bat but no go when I use the key.
jason poeppel
Apr 15, 2017 12:03 PM
millwrightbrian
Feb 18, 2015 03:27 AM
robinhood1995
Sep 4, 2013 01:52 PM
slorider
Mar 23, 2011 02:36 PM
Impacttec1
1997 - 2003 F150
Jul 31, 2006 09:01 AM
