Sponsored by: Real Truck
Different engine?
Old Jul 10, 2016 | 08:44 AM
ugh3012's Avatar
ugh3012
Different engine?
Is it possible to replace my 5.4 2 valves engine with newer 5.4 3 valves engine on the budget on 2001 F250. Will computer module need to be replace. Or is it more cost effective to replace it with the same engine?
Old Jul 10, 2016 | 09:15 AM
seventyseven250's Avatar
seventyseven250
Not sure where you live, but around here, it always seems like a guy could come out ahead just buying a slightly newer truck for a few thousand bucks more, instead of dropping thousands into an existing truck.
Suspect you'd need a newer computer, but not really sure. Good luck.
Old Jul 10, 2016 | 10:09 AM
Bigpipes 35's Avatar
Bigpipes 35
You would be much better off just putting in the same motor as you have. The computer will be different as will be the wiring. The other problem is the 3V came with a different transmission and I am not sure it the bolt pattern on the bell housing is the same between the two 5.4's. On a side note I would not want a 3V as there are two many issues with the cam phazers, I will keep my 2V any day...
alkandt
Dec 6, 2014 02:07 PM
Mark Sawyer
Modular V10 (6.8l)
Sep 21, 2013 03:16 PM
Ducky F150
2004 - 2008 F150
Sep 5, 2013 07:36 PM
Gibby speed
1997 - 2003 F150
Oct 20, 2009 06:03 PM
soonerjoe
Jan 20, 2005 07:44 PM
