2007 F250 Auto. Going to disconnect both batteries this weekend for a couple of hours to upgrade battery cables. Is there a way to not loose shift strategy & Turbo strategy?
Thanks
Ed
Thanks
Ed
You don't lose any programming (except maybe the radio settings and trip meter) by disconnecting the battery cables. If anything it might benefit the transmission by letting it "relearn" it's shifting. The VGT relearn from disconnecting battery cables ONLY affects 03/early 04 trucks.
The stock radio ('05 Excursion) retains it's presets when the batteries are disconnected.
The radio doesn't store the "RDBS" setting (Radio Data Broadcast Setting)
So, if you have enabled the radio to show the song/station ID info, THAT will need to be set again - but all the presets are stored in memory that "remembers" without battery.
