no cranking
Old Jul 8, 2016 | 01:44 PM
kyle692005's Avatar
kyle692005
no cranking
Hey everyone got an 02 7.3 with a no crank issue.will start if I jump the wire on passenger side to battery.replaced transmission switch still no start and now my transmission is acting odd will jump into neutral out of gear.could I have missed something . alignment looks good.
Old Jul 8, 2016 | 02:14 PM
Pikachu's Avatar
Pikachu
From your description, I assume it's a manual transmission, yes? There's a clutch pedal position switch that interrupts the starter solenoid circuit if the clutch pedal isn't pressed, or if the switch is bad. That would be where I'd probably start with it.
Old Jul 8, 2016 | 02:21 PM
kyle692005's Avatar
kyle692005
It's an automatic.i replaced the neutral safety switch with an autozone one
Old Jul 8, 2016 | 06:05 PM
Pikachu's Avatar
Pikachu
Did you align the DTR (digital transmission range) sensor properly when you installed it? Is the shift lever sloppy at all?
Old Jul 8, 2016 | 07:30 PM
kyle692005's Avatar
kyle692005
Yes I believe I aligned it properly seemed pretty simple.yes shifter has a good amount of play. The torx heads are tight in column
78 & 87 Super Cab
May 2, 2015 10:18 AM
Jayme Duty
Feb 21, 2011 02:58 PM
econolow
Aug 28, 2008 08:26 PM
desygityaso
Feb 20, 2008 06:21 PM
Livsgrrl30
Electrical Systems/Wiring
Jan 31, 2004 02:46 AM
