Neutral start switch
Old May 2, 2015 | 07:57 AM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Question Neutral start switch
I have a question, did the '57-'60 manual trans trucks have a neutral start switch? I can start My '59 in neutral without pressing in the clutch. I know later ones you have to press the pedal down before it will start
If it is supposed to have one, where might it be located?
Old May 2, 2015 | 08:16 AM
Walston's Avatar
Walston
They didn't have one, it will actually turnover in gear. After my son near ran over my neighbor, I added a switch to mine that requires the clutch to be pushed. It breaks the wire going from the switch to the starter solenoid. It was quite easy to do.
Old May 2, 2015 | 08:25 AM
Walston's Avatar
Walston
This is what I used. I made a small bracket that it mounted on. When the clutch is not pushed the peddle keeps the button pushed and the switch open. When you push the clutch, the button pops out an the switch closes and you can start the truck. I did the same to serve as a brake light switch.
http://www.summitracing.com/parts/smp-ns69
Old May 2, 2015 | 09:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NSS (Neutral Safety Switch) only used with A/T's.
The switch you're speaking about did not appear on trucks until the 1980's.
Old May 2, 2015 | 10:18 AM
78 & 87 Super Cab
Ok thanks for the info
spaytons
May 7, 2014 07:33 AM
Jdb.ent
Sep 30, 2012 04:24 AM
Jayme Duty
Feb 21, 2011 02:58 PM
84F150driver
Jun 14, 2010 09:14 PM
Livsgrrl30
Electrical Systems/Wiring
Jan 31, 2004 02:46 AM
