Not Cranking
Old Feb 20, 2008 | 04:07 PM
desygityaso's Avatar
desygityaso
Not Cranking
Hello guys. I have a quick question. I have a friend with a 92 f350 manual 7.3 that won't crank over. If I jump the solenoid it will crank but not with the switch. So basicly I'm not getting A signal to the solenoid. It is a manual trans so neutral sensor? clutch sensor? If so how do I check all those wires,lol .that Or Ignition switch? I know this is outta of this forum years but The wiring I beleive is very generic. Thanks in advance for your help guys, DESY.
Old Feb 20, 2008 | 04:23 PM
Cuda_jim's Avatar
Cuda_jim
Turn the key to start, Check to see if you are getting 12 V at the small wire on the starter solenoid mounted on the fender. If so you probably need a new solenoid. If not check the neutral safety switch on the clutch pedal under the dash.
Old Feb 20, 2008 | 05:59 PM
desygityaso
thanks jim . there is no signal from the switch though. the clutch switch has like four wires on it. how do I check it . thank you. desy
Old Feb 20, 2008 | 06:21 PM
Cuda_jim's Avatar
Cuda_jim
Maybe this will help?
bigandblack
Nov 20, 2016 05:14 PM
AubreyA3
Aug 13, 2016 07:33 AM
excelstillmore
Jun 27, 2016 08:00 AM
mentosman42
Mar 23, 2015 11:37 AM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
