Hey guys, I'm going to replace my left hub assy again. I'm going to buy a Timken hub. I need the Motorcraft part numbers for the two seals. I believe one is the axle shaft seal and the other is a dust seal. I also need the Motorcraft part number for the short axle shaft as it has some pitting/scoring.
Thanks Jesser! Do you also happen to know where I can find a u-joint and the outer left axle shaft and what name should I be looking for on the u-joint? I figure I'll get Motorcraft for the axle.
I've bought from these guys a few times. Good quality parts based out of Utah. The Stubs are factory refurbished to like new quality. Kit includes everything you need. They will also install the seal on the stub for you for a few extra bucks.
