Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
replacement connecting rods
Old Jul 5, 2016 | 08:44 PM
bigcrunch's Avatar
bigcrunch
Hi, any manufacturer off stock length for a 391? I found Eagle has a H I think might be to heavy.
thanks,
Old Jul 5, 2016 | 11:11 PM
85e150's Avatar
85e150
Stock rods should be ok if you find a set.
Any aftermarket or different rod will require rebalancing.
What are you doing that requires new or different rods?
You might be better off in the FE/FT forum.
Old Jul 6, 2016 | 09:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
And they should be the same length as a 390/410/428 and I don't think they are any different. What's the casting numbers on the existing rods?
Are you rebuilding and need to replace just one?
Old Jul 6, 2016 | 01:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks,
What year is it? 1964/78: There are THREE different 391 connecting rods!
Old Jul 6, 2016 | 01:41 PM
krewat's Avatar
krewat
And for my own personal curiosity, are they the same as any other FE or FT engines?
Old Jul 6, 2016 | 01:57 PM
NumberDummy
Yes and no, it depends if it's 1964/65; 1966 thru 1970; or 1971 thru 1978.
Old Jul 7, 2016 | 08:30 PM
bigcrunch's Avatar
bigcrunch
Hi, a 76. For the cost of having stock used resized ($80 bolts, $20 for bushings another $150 for the machine shop) there might be value in aftermarket replacement. H beam just to heavy.
Old Jul 8, 2016 | 08:43 AM
NumberDummy
Genuine Ford Parts:
D1TZ-6200-A .. Connecting Rod / Obsolete
1971/72 330 2V Heavy Duty & 361 2V & 391 4V / 1973/78 361 2V/4V & 391 4V
LOCHEN FORD in Newburg WI has 1 = 262-416-5031.
KOEHN MOTORS in Wellington KS has 1 = 620-326-5915.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
MILLER OBSOLETE PARTS in Binghamton NY has 3 = 607-722-5371.
No other Ford dealer or obsolete parts vendor has any.
Old Jul 18, 2016 | 10:43 AM
Destroked 450's Avatar
Destroked 450
The aftermarket H beam rods in my 406 FE engine are close to the same weight as stock rods and lighter than the CJ style rod that came in my engine, also the cheapest set of aftermarket rods will cost more than it does to recondition the stock rods.
I've driven FT powered log trucks and dump trucks along with FE powered cars and pickups. I've experienced a number of engine failures (cracked pistons, cracked cylinders, broken rods, broken cranks, spun bearings and dropped valves) but have never had a rod bolt failure. Unless your building a performance or race engine you can save that $80 on rod bolts and just have the rods reconditioned with new bushings, your numbers make that $170.
Old Jul 20, 2016 | 07:11 AM
bigcrunch's Avatar
bigcrunch
Did you use Eagle?
Old Jul 20, 2016 | 07:47 PM
Destroked 450
They're Scat H-beam rods
ColodadoFordBoys
Aug 26, 2015 05:52 PM
joegeoghegan317
Nov 26, 2004 11:56 AM
Freakazoid!
Mar 1, 2004 06:45 AM
pashtrd
Feb 20, 2003 06:03 AM
GWB
Jan 9, 2000 02:50 PM
