Computer temp sensor for E4OD?
Old Jul 5, 2016 | 08:16 PM
LeoJr's Avatar
LeoJr
I have a gauge that displays what the computer sees and am curious where the computer's trans temp sensor is?
Will it read more accurate or hot than at the test port where more aftermarket gauge's sensors are installed?
Many thanks for the insight...
Old Jul 5, 2016 | 08:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The sensor is on the solenoid body inside the pan. In my opinion it's the most accurate spot to read the temperature.
Old Jul 5, 2016 | 09:05 PM
LeoJr's Avatar
LeoJr
Ok thanks! Is the factory sensor any more or less accurate than the typical aftermarket?
I saw what I thought were some rather high temps (200 to 210) for much longer than I wanted.
(This also renewed my interest in a simple indicator that the TC is locked, or more accurately, signaled to lock, as the trans temp was much easier to control when locked.)
Old Jul 6, 2016 | 01:21 PM
Mark Kovalsky
I suspect it's more accurate, but I've never calibrated either one, so that's just a guess.
200 to 210 is absolutely normal temps for a transmission.
Old Jul 7, 2016 | 07:36 AM
LeoJr's Avatar
LeoJr
Whew...thanks for the normal temp range confirmation.
I have the SD trans cooler lines and bypass in hand, sourcing a 6.0 trans cooler and then will install all.
GoCamping
Jan 4, 2012 09:16 AM
86cherokeek20
Nov 26, 2011 11:14 PM
csramsey640
Jan 18, 2005 04:18 PM
