4R70W overfilled?
Old Jun 19, 2016 | 07:55 PM
rsylvstr's Avatar
rsylvstr
4R70W overfilled?
It is at the mark above the HIGH mark.
Did a transmission plug addition, first filter change and refilled 10 months, 5k miles ago.
Doesn't exhibit any issues at all. But appears to be high, correct?
Do I bother draining some?
Any idea how much will bring it down to the appropriate level?
Can't imagine it's a full quart over, especially without blowing some off/out or having issues.
Old Jun 19, 2016 | 09:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are you checking it with the trans fully warmed up, in park, and the engine idling?
Old Jun 19, 2016 | 09:24 PM
rsylvstr's Avatar
rsylvstr
Yes Sir. Came back from a long drive. Let her idle for about one minute. Then even worked it through the gears which was probably unnecessary. Same reading when cold also.
Old Jun 20, 2016 | 08:14 AM
Mark Kovalsky
That is too high. I recommend removing about a half quart and checking it again.
Old Jun 20, 2016 | 03:11 PM
rsylvstr's Avatar
rsylvstr
Will do. Is the "cold" mark ok to use?
Old Jun 20, 2016 | 03:41 PM
Mark Kovalsky
No, the cold mark is useless. Don't rely on it.
Old Jun 20, 2016 | 04:44 PM
rsylvstr's Avatar
rsylvstr
Thank you again.
Surprised it hasn't exhibited issues with it so high.
Old Jun 22, 2016 | 07:03 PM
rsylvstr's Avatar
rsylvstr
All set. Thx
Old Jul 2, 2016 | 04:53 PM
rsylvstr's Avatar
rsylvstr
Can't win. Nothing major but.....
Drained 4 qts. Added 4. Drove.
Was at bottom of dipstick. Probably due to the four oz left in pan and then drip drip drip and what was in the filter I needed slightly more than 4.
Added half quart drove about 40 miles.
Checked while hot.
Was at "add" just below cold mark.
Added the remainder of the quart.
Now it's well above HOT and probably need to drain some. Almost exact spot on the dipstick as last time I had to drain some. And it ended up being more like 8-10 oz instead of draining half a quart.
How much is it from add line to full?!!!!!!!
__________________
Old Jul 7, 2016 | 10:18 AM
rsylvstr's Avatar
rsylvstr
Drained 6-8 oz out. Now dead smack middle of HOT and should be good.
I might be nuts but I swear she shifted smoother between gears when it was "overfilled."
frankg3079
1997 - 2003 F150
Dec 15, 2012 02:32 AM
Mitch1407
17
Jan 23, 2011 09:55 AM
caleb90
Jan 28, 2010 01:18 PM
DernMooseAk
Oct 11, 2009 06:16 PM
indebt
Jan 11, 2008 07:43 PM
