Best duraspark II module replacement...
Best duraspark II module replacement available? Had starting trouble replace the module with my spare,starting right up.I need a spare one,any one brand stand out.
Motorcraft DY-893 says it won't work("This part is not compatible with 1979 Ford F-250 Ranger XLT Standard Cab Pickup 2-Door 7.5L 460Cu. In. V8 GAS OHV Naturally Aspirated.") but DY 184 does.
Suggestions on what to buy for a spare.
Best duraspark II module replacement available? Had starting trouble replace the module with my spare,starting right up.I need a spare one, any one brand stand out.
Motorcraft DY-893 says it won't work. BS!
("This part is not compatible with 1979 Ford F-250 Ranger XLT Standard Cab Pickup 2-Door 7.5L 460Cu. In. V8 GAS OHV Naturally Aspirated.").
Where did you get this crap info?
but DY 184 was replaced by DY-893
Ebay BS stuff. It had a Switches in it,and when you cross reference it comes up with DY-184 not DY 893
The one I bought (184)
http://www.ebay.com/itm/380694697507?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
And the DY893 that says won't work
Motorcraft DY893 Ignition Control Module | eBay
Getting 12v at coil at start side but would not catch and run,go to on after releasing start it would sound like it wanted to start. It would go puff like it hit on a cyl.Change to spare and instant start.Just swing to start and bam ,starts right up
Mookie's 85
31
01-06-2021 11:58 AM
Matt1966
07-19-2017 04:54 PM
OldMercsRule
30
04-18-2009 11:59 PM
