Ignition Control Module
Old Aug 12, 2019 | 08:29 AM
Red77Ford's Avatar
Red77Ford
Hi I need to replace the Ignition control module on My 1977 Ford F-150 351M The # on the motorcraft module is D6AE12A199A1B searched the archives but could not find the correct motorcraft replacement. Number Dummy or anyone else I need your Help. Thanks Red77Ford
Old Aug 12, 2019 | 10:07 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ignition modules, 74 (black grommet) and 75 (green grommet) are year specific and will not interchange. 76 to 79 (blue grommet) are interchangeable. Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's. DuraSpark ignition modules identified by a colored plastic insert located above where the wires feed out. D4AZ-12A199-C 1974 only. Redmodule is D7AZ-12A199-Aused in some CA vehicles ONLY.
D9AZ-12A199-C(replaced D8AZ-12A199-A). One of these modules isyellow, one is brown.
These modules were used in 1978/79 302 & 351M/W vehicles sold in high altitudes only. 351W: Passenger Cars & Econolines only.
1U2Z-12A199-AA(replaced D6AZ-12A199-B - D7AZ-12A199-B - D8VZ-12A199-A - D9VZ-12A199-A) Ignition Module -blueinsert (Motorcraft DY-893)
Available from Ford and here are some possible sources below.
Green Sales in OH.
Collectors Auto Supply in WA.
Haven Ford in KS.
Klimesh Motor Sales in IA.
Bob Allen Ford in KS.
Freese Motor Inc in IA.
Wesley Obsolete Parts in KY.
Dennis Carpenter Ford in NC.
Here is an updated list from ND. https://www.ford-trucks.com/forums/1...l#post14777178
Old Aug 12, 2019 | 11:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The ID engineering # on the Motorcraft module is D6AE-12A199-A1B
D6AZ-12A199-B .. Ignition Module / Marked: D6AE-12A199-A1A or A1B or A2A or A2B / Replaced =
1U2Z-12A199-AA (replaced D6AZ-12A199-B, D7AZ-12A199-B, D9VZ-12A199-A) .. Ignition Module - Blue Grommet (Motorcraft DY-893) / Available from Ford
1976/90's myriad FoMoCo vehicles.
Old Aug 12, 2019 | 11:38 AM
Red77Ford's Avatar
Red77Ford
Plugs are the same color wires but orientation is different white, orange, purple, black, red, green on my original Does this matter?
1U2Z12A199AA Ford Replacement wire orientation is different than my original
Old Aug 12, 2019 | 11:55 AM
NumberDummy
I don't know anything about this module, it's a 21st Century FoMoCo replacement part number.
I'd look for an original...this is the most common part number, there may be more on ebay.
D9VZ-12A199-A =
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
MUSTANG'S ETC in Van Nuys CA has 1 = 818-787-7634 (this may be an auto parts store replacement).
Old Aug 12, 2019 | 01:49 PM
dustyroad's Avatar
dustyroad
rock auto has one.
oh and slight thread hijack, where can you get the harness plug that plugs into that module?
Mine is on it's last days with wire exposed. I see rock auto has them as well but they appear to be for the module side, I couldn't tell really.
Old Aug 12, 2019 | 04:05 PM
matthewq4b's Avatar
matthewq4b
Wire orientation does not matter it is the same unit. Ford has revised or should I say Airtexx/Wells ( Current OEM supplier) has revised the PCB many times
orion1968
Feb 12, 2025 08:13 AM
Placermike
North Carolina Chapter
Mar 31, 2008 02:08 PM
dawgs150
Delaware Chapter
74
Aug 12, 2007 07:14 AM
edsf100
41
Jan 13, 2007 03:50 PM
93PGT
Nov 15, 2006 10:00 AM
