A/C blower switch problem
Old Jul 5, 2016 | 03:26 PM
Eli1644's Avatar
Eli1644
Ok, now I'm at another stump. Number dummy, I need your help again. My blower motor fan is not sold at parts stores either. The one they sold me, the diameter is smaller and the fins are facing the other direction...
Old Jul 14, 2016 | 03:14 PM
Eli1644's Avatar
Eli1644
So, I'm pretty much done with the sanden conversion AC kit. My truck has been at the AC shop for about 4 days. I would have picked it up today but the shop owner calls me and says it's blowing ice cold,But he feels heat mixing in with the cold air. He said he will look into what is causing that. I replace everything in that truck involving the AC. From the condenser under the hood, to all the way to the switches in the dash.( except most of the original wiring) I have came down to 2 things I maybe did wrong. I hooked up the lines going into the heater core backwards. And the valve is not operating the way it should be? That valve or motor? That has a vacuum hose Hooked up to it ,stops the flow of radiator fluid going to the heater core, unless your swipe the switch on the dash to heat to get heat?.(is this how it works?) or the other less likely reason is that I didn't insulate the heater core and evaporator core enough to prevent them effecting each other's temperture. What do you guys think? Any responses are welcome. In the case of anything else being wrong, I'm pretty sure everything is right where it's suppose to be.
Thanks
Old Jul 15, 2016 | 07:55 AM
Eli1644's Avatar
Eli1644
Bump! Anyone???
Old Jul 22, 2016 | 04:00 PM
Eli1644's Avatar
Eli1644
Well, unfortunately my truck's AC is only blowing 77-75 degrees. After two shops and about an extra 250$ of shop bills I'm still not getting anywhere. They both say drive the truck to classic air auto and see what they say. Could there be a sensor or something else that is keeping the AC from dropping below 75 degrees. I really need yall's help in this one. The wife is not liking how much money I have been blowing on the truck. If she only knew how much more money I have actually spent. Lol. But please of anybody has some insight or point me in the right direction. New parts have been replaced already. So everything is completely new.
Old Jul 23, 2016 | 03:36 AM
benbuilder's Avatar
benbuilder
subscribed to learn. sorry no answers here
Old Jul 23, 2016 | 07:57 AM
kegger66's Avatar
kegger66
see thread https://www.ford-trucks.com/forums/1...-sanden-2.html
Old Jul 23, 2016 | 08:30 AM
Eli1644's Avatar
Eli1644
Thanks Kregger for the replies. Yes the little door by in front of the evaporator opens and closes as it should. Right now I have the heater core bypassed to prevent hot and cold mixture. And I replaced my fan clutch about 2-3 years ago. Still working perfectly fine. 6 blade fan also
Old Jul 23, 2016 | 08:59 AM
kegger66's Avatar
kegger66
Well I'm out of suggestions, like you said - it's a new system end-to-end and sounds like all the parts are working related to it. I'm just wondering if the PAG oil type/amount is correct with the R134 and if the dryer was exposed to too much open air before it was hooked up... but those are straws I'm grasping for.
Were the 2 shops AC specialist or a "fixall" ? I know the wife won't be happy but the classic air folks might be the next stop.
Old Jul 23, 2016 | 11:00 AM
Eli1644's Avatar
Eli1644
Yeah I appreciate the help. Maybe the oil could be the problem. I'll ask the technician if he checked for the pag oil. I appreciate all the suggestions. I hope you AC holds up nice and cold for years to come Kregger, lol... I'm envious
Old Jul 23, 2016 | 11:01 AM
Eli1644's Avatar
Eli1644
And the 2 shops are specialist. Very highly recommended here in Florida.
Old Jul 24, 2016 | 07:20 PM
kegger66's Avatar
kegger66
you'll get there Eli - there is something amiss in the setup that we just haven't figured out yet. Keep me posted on your next steps.
Old Jul 26, 2016 | 03:30 PM
kegger66's Avatar
kegger66
FYI: I talked to the shop that charged mine and they used PAG Oil and R134A. (Not Ester or Mineral oil and Freeze12)
spikedog
26
May 19, 2020 06:30 AM
vettman
Jun 7, 2018 08:31 AM
rcummings
Aug 3, 2012 04:35 PM
Tenderpaw
May 29, 2012 09:15 PM
MTGunner
May 5, 2009 05:12 PM
