Sponsored by: Real Truck
Heater/AC blower switch?
Old Apr 29, 2009 | 07:44 PM
MTGunner's Avatar
MTGunner
My 2001 F250, 7.3L, blower motor switch has to be turned to high to get blower motor to operate. Heat and AC work great! Is the switch an individual switch or are the three dial *****, located near each other, a one piece unit? Also, how much trouble to change the switch or unit? Thanx in advance for the help.
Old Apr 29, 2009 | 08:52 PM
carls 250's Avatar
carls 250
Look @ the blower resistor it sounds like it failed. quick test is to check the diod on the resistor.
Old May 4, 2009 | 04:20 PM
MTGunner's Avatar
MTGunner
Question Location of blower resistor?
I have checked everything other than the resistor that you are refering to. Where is this resistor located?
Old May 4, 2009 | 08:14 PM
carls 250's Avatar
carls 250
blower motor
the blower resister is shoud be right next to the blower motor.
Old May 4, 2009 | 10:47 PM
dchamberlain's Avatar
dchamberlain
Try this diagram
Old May 5, 2009 | 05:12 PM
MTGunner's Avatar
MTGunner
dc, I found the problem and have effected a repair. I located the resistor array, thanks for the pic, and removed it. I went thru the process of checking the continuity of the diode, or what I thought was a diode in the circuit. Turns out that what I thought was a diode, in reality, is a thermal fuse rated for 151 degrees celsius and approx. 300 degrees farenhiet(sp). I went to my local Radio Shack and they looked it up on their data. According to the Radio Shack manager. The replacement thermal fuse is a Radio Shack part #270-1320. This cost a total of $1.69. I soldered it in to replace the original, replaced the connector and turned the blower switch to each setting with great results. My blower motor works great! Be sure to use a heat sink in soldering in the thermal fuse to insure that the soldering iron heat does not blow the thermal fuse. Thanks ever so much for your help in this repair.
hotrod351
Jul 29, 2016 12:50 PM
mribbich
May 19, 2016 01:22 PM
excaliberprime
Jun 29, 2014 05:08 PM
puck1263
Aug 9, 2006 08:45 PM
Rockfrog
1978 - 1996 Big Bronco
Dec 28, 2002 04:04 PM
