Gear shift indicator replacement
Old Jun 29, 2016 | 07:41 PM
shadows4's Avatar
shadows4
Hey guys, I have been looking and not found any threads mentioning this. I need to replace the cable on my gear shift indicator. Of course you can't just replace the cable. I have even looked on you tube and not found anything. I don't know if maybe I am using the wrong search terms or not. Any way I would appreciate any advise or help I can get. Going to try to do this next week as I will be on vacation. Thanks, John
Old Jun 29, 2016 | 07:53 PM
163junk's Avatar
163junk
Easy job, Remove the cluster mount screws, 2 small black tabs at base of indicator push them in an pull down. On the bottom of the column just 1 single screw holding cable and thumb screw and the cable just has a loop over the shift tube. Reassemble and use the thumb screw to adjust your indicator , I do it in neutral.
Old Jun 30, 2016 | 08:02 PM
shadows4's Avatar
shadows4
Thanks Steve, it worked like a champ.
katdaddy
1983 - 2012 Ranger & B-Series
Oct 1, 2013 04:45 PM
midsouth
Oct 21, 2011 07:39 AM
Dale in WV
Jun 28, 2006 07:16 PM
jbalestri
1997 - 2003 F150
Nov 13, 2003 08:26 AM
kinglg
Jun 19, 2003 10:13 AM
