Shift cable adjustment
Old Jun 16, 2003 | 10:58 PM
kinglg's Avatar
kinglg
Does anyone know how to adjust the shift cable on a 93 F250?
I am having a hard time putting it in park.
Old Jun 17, 2003 | 04:56 PM
rclarke's Avatar
rclarke
Check the shift tube along the top of the steering column. If you reach under the dash to where the cable is attached the shift lever and the lever the cable is attached to should move together. The shift tube is pot metal supported in plastic bushings. I have changed at least a couple hundred of the shift tubes that were broken. Make sure the cable is freemoving in its housing too.
Old Jun 19, 2003 | 12:11 AM
kinglg's Avatar
kinglg
I think my cable is streched out. Is that possible? The
shift tube is not broken as I had to replace it a few years
ago. There seems to be a lot of play in the shifter and now it will not go into park at all. The shift tube was the first thing I checked. The only place I could see to adjust
the cable is on the transmission end. It looks like some
kind of plastic lock piece that will break if you try to
move it. Any info on that?
Old Jun 19, 2003 | 10:13 AM
steve83's Avatar
steve83
I've never seen one break. This site probably shows how to set it.
Grease & Gravel
19
Jan 19, 2025 11:27 AM
1990-f250
Mar 7, 2017 10:11 AM
pdqford
Jun 30, 2016 11:33 PM
FUBARHUBAR
1997 - 2003 F150
Jul 28, 2015 05:40 PM
Blue Bomber
Aug 22, 2008 09:18 AM
