Changing tire size with AE
Old Jun 22, 2016 | 01:20 PM
AllaboutMPG's Avatar
AllaboutMPG
Hi gang . Is there a way to select your own tire size and not use AE's preset numbers. With 32 selected, checking it against GPS and mile markers I'm about 1% off about a mile per hundred. I went to change it and the only selection it will allow is 32.25. With that setting I'm off the other way. Can't find a way to select my own numerals. Am I missing something or is this just one of those it is what it is situations. Thank you
Old Jun 22, 2016 | 01:24 PM
Jesser02EX's Avatar
Jesser02EX
I hope someone had this answer as I'm having the same issue with the presets.
Old Jun 22, 2016 | 01:39 PM
JayTheCPA's Avatar
JayTheCPA
Just asking, is it about 1% off, or a static offset across the speed band?
My speedo is consistently 2mph off at all speeds. Was that way from day 1.
Old Jun 22, 2016 | 01:55 PM
AllaboutMPG
When I had it set to 32 inches the spedometer appear to be dead on but it's hard to see a 1% error. When I said it to 32 and a quarter I can actually see the disagreement across the speed band the truck says it's going about 1 mile an hour faster than it really is. I'd like to be able to make smaller adjustments than a quarter inch. Say .1 or .15. I know 1% seems a little **** but I hand cancalculate mileage and I like for it to be accurate
Old Jun 22, 2016 | 02:11 PM
Dan V's Avatar
Dan V
So do you compensate for tire wear too?
Old Jun 22, 2016 | 05:14 PM
AllaboutMPG
These are brand new tires. That's what got me to changing the size to begin with. Like I said I know I'm being a little **** but I just wanted to see if I could play with it and get it exact
Old Jun 22, 2016 | 06:56 PM
Dan V's Avatar
Dan V
Well at least you acknowledge your OCD.
Old Jun 23, 2016 | 07:15 AM
Tugly's Avatar
Tugly
We are stuck with the presets in there - they are part of the ABS system. I have learned one thing by playing with all the buttons: I'm either dead-on for speed or dead-on for the odo - but never both. I opted for an accurate odo because I figure my fuel economy with that. My speed plus or minus a few percent is not as critical.
Old Jun 23, 2016 | 09:23 AM
SRBF150's Avatar
SRBF150
Tugly, what have you found is the delta in mph between an accurate mph v. odo?
Old Jun 23, 2016 | 11:59 AM
AllaboutMPG
I agree Rich, Odo is more important than speedo. Guess I'll have to play with it, see which is closest and compensate manually.
Old Jun 23, 2016 | 12:08 PM
spongecop's Avatar
spongecop
Semper Fi
I emailed AE last year and asked if we could adjust for tire size...they said no.
Old Jun 23, 2016 | 12:43 PM
AllaboutMPG
Pete- F250-- did this nice write up awhile back. I was just looking to refine the adjustment. Guess not
https://www.ford-trucks.com/forums/8...iguration.html
Old Jun 24, 2016 | 05:22 AM
Tugly's Avatar
Tugly
The speedo reads high by a couple of miles per hour at highway speed (60-65) when the odo is dead-on.
LostKnyt
2009 - 2014 F150
Jun 28, 2014 10:19 PM
boulderbronco
6.4L Power Stroke Diesel
Jul 9, 2013 09:28 PM
chado
2004 - 2008 F150
Jan 14, 2010 07:19 PM
tpepper
Modular V10 (6.8l)
Nov 28, 2007 10:16 AM
Opiewan
34
Nov 17, 2003 05:50 AM
