Washed engine compartment...
Old Jun 20, 2016 | 08:43 PM
rlansdon's Avatar
rlansdon
Over the weekend I found out I had quite a massive oil leak. So, in order to determine where it was, I tightened my valve covers, unhooked my batteries and degreased my engine with a hose. After refilling with almost a gallon of oil and cleaning I tried to crank up the truck. It started but then the rpms would drop and the check engine light would flicker on, then idle normal and back and forth it goes.. Any ideas??
Old Jun 20, 2016 | 10:09 PM
z31freakify's Avatar
z31freakify
One of the connector to the sensor is shorting out with the water you rinsed it with unplug every sensor and use compress air to dry them out.
Good Luck.
Old Jun 20, 2016 | 11:39 PM
rlansdon's Avatar
rlansdon
Good Luck.
Thanks I'll try that!
Old Jun 20, 2016 | 11:53 PM
timmyboy76's Avatar
timmyboy76
Make sure you covered the alternator and power steering cap
Old Jun 21, 2016 | 05:24 AM
JOHN2001's Avatar
JOHN2001
And use die electric grease on all connections to stop that from happening again
Old Jun 21, 2016 | 03:11 PM
SteveH-CO's Avatar
SteveH-CO
Any time you power wash an engine, it's also a good idea to take a long hot drive to drive moisture out of various places it shouldn't be.
Old Jun 21, 2016 | 03:15 PM
HKusp's Avatar
HKusp
You really never should pressure wash an engine that is installed in a vehicle. Water under pressure blows past the seals in the all weather connectors and gets in places you don't EVER want water to infiltrate. Always cover the alternator and PS reservoir with plastic bags, spray a COOL engine liberally with simple green or other mild degreaser of your choice, rinse with low pressure hose water, repeat as necessary. When satisfied, remove the bags, then start her up and go for a ride.
Old Jun 21, 2016 | 05:11 PM
SARDiverDan's Avatar
SARDiverDan
I have washed mine several times over the years and while I use a small piece of aluminum foil over my PS cap, I have never covered the ALT. I also soak it down with simple green, let it set 5-10 minutes and then rinse it off with the hose on shower setting.
Old Jun 21, 2016 | 05:39 PM
HKusp's Avatar
HKusp
The reason for covering the ps cap is there usually is a little hole in it for breathing. It is so small, it would be very hard for water to enter, but in the right circumstance, it could.
Old Jun 21, 2016 | 05:53 PM
DuncanCloud's Avatar
DuncanCloud
I have an electric leaf blower that I use to help dry out the engine bay before I try to start it. Nothing too harsh, just a nice flow of air that isn't overly aggressive.
Old Jun 21, 2016 | 06:07 PM
Jaime74656's Avatar
Jaime74656
You have water some place it should not be, most likely the alt, my 95 did as described, but after getting the engine to operating temperature and driving around for about 30 minutes all was good
Old Jun 21, 2016 | 08:27 PM
rlansdon's Avatar
rlansdon
Thanks everyone. Running nicely now. Just needed longer to dry.
Old Jun 21, 2016 | 09:36 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Don't be afraid to pressure wash you engine compartment. I have Hotsy'ed mine for years without issue. I have been washing engines for more than 40 years with never a problem, but then again knowing water and electricity are not good bed fellows I avoid electrical components as well as any type of cap area, especially oil caps. Just saying. I was a trained heavy equipment mechanic for the Marine Corps and an ASE certified mechanic upon discharge.
djed
Aug 12, 2013 12:15 AM
02stroke
Feb 24, 2011 07:43 AM
earl964
Mar 17, 2008 11:47 AM
dieseloholic
Jul 16, 2007 07:29 PM
