Sponsored by: Real Truck
5R110 Odd Noise
Old Jun 19, 2016 | 06:40 PM
DesertSmoker's Avatar
DesertSmoker
5R110 Odd Noise
Heard a ticking noise when you roll the rear drive shaft. I pulled the t-case checked it, it is smooth and quiet, ticking noise is not in the t-case. Grabbed the output shaft on the trans with it in neutral. Rolled the it found the ticking noise in the trans. Any one else seen/heard this issue?
The noise is like a plastic tab riding on a splined shaft rotate=tick
Truck is 2010 F-350 4x4 v10 auto and 271F T-case 98k miles on it.
Old Jun 19, 2016 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've heard it before. It's the one way clutch. That's normal for that clutch.
Old Jun 20, 2016 | 09:15 AM
DesertSmoker
Thanks Mark! I am glad to hear it is normal for that trans. Do the 03/04 5R110 have a different clutch setup in them? I used my 03 psd to compare the 2 and it is quite when rolling the drive shaft
Old Jun 20, 2016 | 04:06 PM
Mark Kovalsky
No, they are the same. With production tolerances some are noisier than others.
Old Sep 5, 2018 | 04:48 AM
MarkG.'s Avatar
MarkG.
I know this is an older post, but I've had the same noise in mine and it's been driving me crazy. I've been doing research but haven't found anything until now. It's a relief to know that nothing is wrong with the transmission.
andyman1961
Jul 4, 2015 08:52 AM
Camsdad
Jan 21, 2014 03:40 AM
Hunt89
Sep 3, 2009 11:49 AM
UncleD
Apr 3, 2007 04:43 PM
joes75
Bronco II
Jun 17, 2002 11:11 AM
