Clutch making funny noise. Need HELP!!!
Sound kinda like a 5gal bucket laying on its side about half full of gravel spinning?
Regardless of the actual sound heard I suspect the trans input shaft bearing is shot. The input shaft spins with no load with the trans in neutral with the clutch pedal out. Pushing and holding the pedal in drastically slows down or stops the input shaft from spinning stopping or reducing the level of noise the bearing produces.
