Motor plate question?
Old Jun 19, 2016 | 02:42 PM
FuzzFace2's Avatar
FuzzFace2
Question Motor plate question?
I did not see this when the motor & trany were apart and out of the truck but the motor plate is missing on my project.
It is an 81 300 I6 T18 trany and from what I have seen posted the bell bolt pattern is the same as the small block v8's, is this right?
If so would this be up to the 351 family (all 351"s?) and what years?
Is it different between auto & stick tranys and if so what is the difference?
Thanks for the information a head of time.
Dave ----
Old Jun 19, 2016 | 05:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
On my truck (460) the plate is used to locate and space the starter.
the plate is the same for automatics and manual gearboxes.
The Windsors and the 1-6 engines share a bolt pattern. (351W)
The 335 and 385 series share a bolt pattern. (351M)
Diesels have yet another.
I'd imagine Windsor's use the same plate but have no idea if the 300 has the same starter location.
In fact I doubt it.
Old Jun 19, 2016 | 09:07 PM
Gary Lewis's Avatar
Gary Lewis
The 300 uses a different plate, as shown here: Engine Plates - ???Gary's Garagemahal
Old Jun 19, 2016 | 09:29 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Interesting Gary, that the 460 changed plates when it went to EFI.
The C6 and T-19 were both still available in '88.
Used the same starter...
I wonder if this was the root of my starter woes?
Old Jun 19, 2016 | 09:32 PM
Gary Lewis's Avatar
Gary Lewis
That's a really good question! Might explain something.
Old Jun 20, 2016 | 02:57 AM
FuzzFace2's Avatar
FuzzFace2
Thanks guys, so it looks like it is a 300 only plate.
That was for 1980 would it be the same plate up to the end?
I ask because of the 460 plate change with EFI you guys talked about.
Thanks again
Dave ----
Old Jun 20, 2016 | 03:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FuzzFace
So it looks like it is a 300 only plate.
C5AZ-7007-A .. Engine Rear Plate - Use with M/T / Obsolete
1965/67 E100 240 I-6 / 1965/72 Galaxie/LTD 240 I-6 / 1965/74 F100/350 240/300 I-6 / 1969/74 E100/300 240/300 I-6 / 1975/96 F100/350 & E100/350 300 I-6.
No I-6 available in Galaxie/LTD after 1972. 240 I-6 cancelled at the end of the 1974 model run.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
DON'S TRUCK SALES in Fairbank IA has 1 = 319-635-2751.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 38 = 800-476-9653.
Gary, Chris and maybe some others in this forum only have the 1980/89 Ford Light Truck Parts Catalog, so they probably aren't aware of the myriad 240 & 300 I-6 applications I posted.
Old Jun 20, 2016 | 06:36 AM
Gary Lewis's Avatar
Gary Lewis
Dave - The "6 cyl" row on that page says "80/", which means from 1980 to the end of the catalog, which was 1989. But, as Bill points out, it started being used in 1965 - as you can tell from the "C5" in the prefix. And, Bill tells us it was used out to 1996. So, it is probably available in a salvage.
Old Jun 20, 2016 | 10:13 AM
FuzzFace2's Avatar
FuzzFace2
Thanks guys if I didn't ask I would have been looking at small block ones also.
I will check for a used one, heck most guys chuck them when going to v8.
Dave - - - -
F&M
Jan 16, 2014 04:41 PM
JoryCustomSolutions
Oct 18, 2009 10:18 AM
rjvaughan
Sep 18, 2007 06:09 PM
71F250camper
Jul 27, 2005 02:15 AM
olfordsnstone
Nov 22, 2003 09:19 PM
