The axle total weight ratings (18K) would be determined by max trailer load weight. What is the empty weight? This would tell you if safe to run empty on 2 axles.
Would it do anything funny with the brakes having one axle "disconnected" from the pavement like that? How often do you run it empty? Seems like a lot of hassle for pretty minor gain.
Sure, you can run with tires off an axle. On spread axle semi trailers some will lift the axle when empty safe wear and tear. But that's an instance of flipping a switch.
