Information Display... New Info....??
Old Jun 17, 2016 | 06:38 PM
David_ski's Avatar
David_ski
This afternoon when I started up my truck there was additional information on my instrument cluster display that was not there in the previous 1,900 miles. It is the transmission gear indicator on the right hand side.
I have seen posts from others showing their display that does and does not show the current transmission gear. I assumed that it was just a earlier SW version that showed the current transmission gear. I find nothing in the manual about the transmission gear indicator. It is displayed on all of my information display screens.
NO, it was not always there the previous 1,900 miles, and I just did not notice it. It was NOT there the previous 5 weeks. The only thing I did different today before I noticed it being ON, I had to back up about 500-1,000 feet before I could turn around. As soon as I put it into drive after the reverse run, the gear indicator was there.
What gives? How did it get turned ON?
I like it ON. Yes, it goes away when I am in P-R-N. It comes back on when I put it into Drive.
Will it mysteriously turn itself off sometime in the future?
Old Jun 17, 2016 | 06:54 PM
JohnD333's Avatar
JohnD333
David,
There is an up/down switch on the gearshift selector- about 4 inches in from the end. Up once indicator goes away; up again and it comes back. You probably bumped it accidentally. With new truck, or whenever a major reflash of control modules, it goes back to "no show."
If in M rather than D, you can shift up and down gears with it. If in D, you can lock out the higher gears by pressing the down one or more times depending upon how many of the top gears you do not want to use.
Old Jun 17, 2016 | 07:03 PM
David_ski's Avatar
David_ski
Originally Posted by JohnD333
David,
Thanks. Yes, I verified that is how it gets turned off and on.
Old Jun 18, 2016 | 07:36 AM
Big-Foot's Avatar
Big-Foot
Odd... I don't manually shift my truck and I thought I remembered this display showing which gear it was in while the truck was automatically up/down-shifting... Went looking through my pictures and found one that clearly shows the same gear indicator..
WarriorDog
Dec 12, 2024 06:32 AM
firecapt13
Jan 4, 2019 08:23 AM
Subsailor1127
6.7L Power Stroke Diesel
Mar 26, 2015 10:19 AM
r___r
All Things Towing
18
Oct 13, 2014 01:13 AM
jh225
Jul 6, 2012 09:56 PM
