Gear on display?
Old Mar 25, 2015 | 05:24 PM
Subsailor1127's Avatar
Subsailor1127
Gear on display?
Hello all. I know that when you are in the manual mode you can see which gear you are in on the right hand side of the small display between the speedo and tach (forget what that display is called). Is there a way to configure that screen so you can see which gear you are in while in "Drive"? With six gears to go through and these things shifting so smooth, I just think it would be nice to be able to tell what gear you are in at any particular time (especially when towing). -Glenn
Old Mar 25, 2015 | 05:45 PM
Lawrencew's Avatar
Lawrencew
Yes
I believe if you touch the paddle shift button up or down it will display the gears .
Old Mar 25, 2015 | 05:57 PM
pjcinmi's Avatar
pjcinmi
Anytime your are in D just press the + button once and it will show the display. The display will then show you what gear the truck is in or when it shifts. Until you press the - it will not lock out any gear 1-6. You have to turn it on each time you re-start the truck however. Tow Haul mode does NOT have to be on for this to work.
Old Mar 25, 2015 | 06:21 PM
BigBlueOx's Avatar
BigBlueOx
I agree with everything else but my truck does not need to be reset every time I restart the truck. Once it's set, it set. Maybe it's a year thing. But I know '13s and '14s don't need to be reset either.
Maybe it's a base model cluster / Platinum model cluster difference.
Subsailor1127
Great, thanks guys.
Old Mar 25, 2015 | 06:24 PM
Iowa Ford's Avatar
Iowa Ford
My 12, stripped XLT. doesn't need to be reset each time either.
Old Mar 25, 2015 | 06:26 PM
BigBlueOx's Avatar
BigBlueOx
So it must be the "XL cluster" I'll call it.
Old Mar 25, 2015 | 06:29 PM
RigTrash601's Avatar
RigTrash601
What he said. Just press the button, you can also "lock out" gears if you like, just keep pressing the button and the display will cycle through the numbers for the corresponding gear, if you want 5th &6th locked out, just cycle thru to 4., and so on.
Old Mar 25, 2015 | 06:31 PM
pjcinmi's Avatar
pjcinmi
I have been known to be wrong before!!! I'll have to check it later.
FYI I have a 15' Lariat
Paul
Old Mar 25, 2015 | 06:33 PM
RigTrash601
I have a '13 F150 XL work truck, it doesn't need resetting either.
Old Mar 25, 2015 | 08:01 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Paul
Hi Paul......
If the gear numbers are displaying when you shut off the truck....they come back when you restart. This was true with my 2011 F-350 and my current 2015 F-350......
Old Mar 26, 2015 | 04:26 AM
Mtncrash1's Avatar
Mtncrash1
Originally Posted by Sailor_Roy
Hi Paul......
Right on the money. The only thing that needs reset is if you have locked out any gears.
Old Mar 26, 2015 | 06:52 AM
Gints's Avatar
Gints
Press +/- button strait down a middle, when in D. That switches gear display ON/OFF.
Old Mar 26, 2015 | 07:30 AM
Rattler1's Avatar
Rattler1
I just have to push the + button when all the numbers are lit and the gear indicator will toggle getween being lit or dark.
Old Mar 26, 2015 | 10:19 AM
17 Oaks's Avatar
17 Oaks
My '15 does not have to be reset unless I hit the button, other than that it stays on once I have set it.
David_ski
6.7L Power Stroke Diesel
Jun 18, 2016 07:36 AM
hoverp
22
Apr 5, 2014 11:36 PM
jh225
Jul 6, 2012 09:56 PM
jade97
2009 - 2014 F150
Jun 29, 2011 10:09 AM
don.joyce59
Nov 4, 2010 07:47 AM
