6-1 Gear Lights?
Old Jul 6, 2012 | 07:50 PM
jh225's Avatar
jh225
6-1 Gear Lights?
So my 2012 is about a week old. Today while driving, I notice that the gear position light up display above the normal PRNDM21 is lit up displaying what gear I am in (even though I am not in manual mode). I'm wondering if that is normal and if so, why has it not been lit up for the past week? I would have definitely noticed it if it was, as I have put over 1K miles on it running hay over the past week. Even have driven in the dark when it would be obvious.
Old Jul 6, 2012 | 08:32 PM
RobFlag's Avatar
RobFlag
When not in manual mode, you can turn that display on and off with the manual selector switch on the gear shift lever.
Old Jul 6, 2012 | 08:41 PM
Cable Guy's Avatar
Cable Guy
In conjuction to what RobFlag stated, the + and - buttons in the automatic shift lever turns the 1-6 gear display on and off. Also, when in auto mode if you push the - button it will lock out gears. For example if you are in 6th gear and push the minus button, the truck will down shift to 5th gear and that will be your top gear. If you push it again it will downshift to 4th and that becomes your top gear. It will still upshift and downshift automatically, but it will only go up to the highest gear on the display. Hope this helps.
Old Jul 6, 2012 | 09:56 PM
jh225's Avatar
jh225
Thanks guys, that's really interesting. I guess I must have hit the little button when shifting from park to drive.
Ridge
Nov 16, 2015 05:35 AM
Pit Crew
Apr 6, 2014 07:45 PM
jade97
2009 - 2014 F150
Jun 29, 2011 10:09 AM
kbhblazer
6.2L V8
Mar 30, 2011 08:15 PM
don.joyce59
6.7L Power Stroke Diesel
Nov 4, 2010 07:47 AM
