2001 excursion code46
Old Jun 15, 2016 | 03:08 PM
ATVTHEO's Avatar
ATVTHEO
Need help. I researched code 46 and tried the wd40 on connectors under drivers seat with neg results. Can anyone give me any other reasons the AIRBAG light might stay on? I don't know why but sometimes the light would go out unexpectedly but will always come back. Any help would be appreciated this light is annoying.
Old Jun 15, 2016 | 06:10 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
What code are you referring to with for 46? What's the prefix on the code?
Old Jun 15, 2016 | 09:25 PM
ATVTHEO's Avatar
ATVTHEO
Im not sure what you mean? I just counted the number of times the light blinked. Not sure about prefix?
Old Jun 16, 2016 | 12:06 AM
Krazee Matt
Veteran: Navy
Well that explains that then. Even without a CEL the PCM should still have stored a code. P0720, P0308, P0475, etc. Those aren't pertinent to your issue, just examples. Try getting the codes read with a legitimate scanner and see what you find, it may point you in the right direction. The light blinking trick is for school stuff, usually on OBDI systems.
Keep in mind for technical or mechanical issues, an auto parts free scan usually won't pull the codes. For this however, you should be fine as it's not powertrain related.
Old Jun 27, 2016 | 03:39 PM
ATVTHEO's Avatar
ATVTHEO
Okay I used my Bluetooth driver and these are the codes I pulled: Still trying to get that airbag light off. Already cleaned connecter under driver side seat with no success.
1 Powertrain Control Module Trouble Codes:
1. P1000
On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
----Anti-Lock Brake Module Codes Scan Report----
1 Anti-Lock Brake Module Trouble Codes:
1. C1226
Brake warning indicator output short circuit to ground.
----Restraint control Module Codes Scan Report----
2 Restraint control Module Trouble Codes:
1. B1885
Safetybelt Driver Retractor Circuit Failure
Treetruckt9
Feb 22, 2019 12:20 AM
MichaelKnight
1983 - 2012 Ranger & B-Series
Jan 26, 2011 09:51 AM
afonda
Nov 15, 2008 09:26 PM
Rick32
1997 - 2003 F150
Apr 14, 2006 05:21 PM
bluene
Jun 5, 2004 02:19 PM
